I can't enable Frame Generation in Unreal Engine 5
Hello, I’m having trouble enabling Frame Generation in Unreal Engine 5. I have an RTX 4070 Ti, but when I try to enable it, nothing happens. Could someone help me? Thank you.
As seen in the image, in the developer statistics:
Supported API: Blank space
Hardware Scheduling Required: False
Vertical Sync Off Required: False
Sorry, I couldn’t upload the image in proper quality, but in both cases, with Frame Generation enabled and without it, the FPS remain the same (85 FPS).
Hi there @tropi-cal and welcome to the NVIDIA developer forums.
The FPS counter you point out here does not reflect the additional frames generated. It always shows the base frame-rate.
If you run the sample in standalone game mode or pop out PIE the status view of the sample will show the difference.
Thanks Markus
