Hi! My PC 5950x+4090, and FG work in cyberpunk 2077, but not work in Unreal. DLSS is work, trouble only with FG… How to fix?
Hi boris,
For one you will not see any changes in the integrated frame counter of Unreal when enabling FG. Frame Generation happens outside the measured render cycle of Unreal Engine.
Secondly, your system is so powerful that you might actually not gain anything at 1440p with FG for such a simple sample scene.
If you see the side menu stating FG is enabled and supported, it is running. Check the logs and unless you see error messages about DLSS, things are fine.
Hi, thanks for the quick response!
indeed, I found on the same day that only works in a compiled application, and really increases fps by 80%! however, I need it for vr, and I can’t find the unreal dlss 3.5 plugin anywhere, which works based on the forums, can you help me?
Sadly we don’t keep older releases of the plugin for new UE versions available on our download servers for various reasons.
And on top of that the topic of VR is very complicated. There is no official support either from Epic or from NVIDIA for any upscalers within VR in UE.
In the editor, it seems that “Frame Generation” only works properly in the preview window for the first time, and after canceling the operation, the “Frame Generation” remains in the on state. Even when running in the viewport, it shows that “Frame Generation” is effective, but the on/off state of “Frame Generation” can no longer be modified.
It doesn’t work at all for me until I compile the application. But okay with that, I would like to find dlss 3.5 so that I can work with FG with VR, otherwise the project will end soon, and the framerate will be low without it (
- There is an option “Enable DLSS-FG in New Editor Window mode” in the project settings, and it is turned on by default.
- Update the NVIDIA graphics card driver.
You can check it.
Very interesting… But it crash any project, even Base dlss3 project. Drivers 560.70. Work if compiled in standalone exe
I don’t know why, but it’s working and it’s not working, you’re a genius! I’ll figure out VR and finally be able to work properly in UE!
