Edit 4:
Both HTML5 and flash video seem to tear in Firefox. The issue goes away if Chromium is used. So I will hope Firefox gets fixed and use Chromium in the meantime for video playback.
OS: Mint 18.1 fully updated with the most aggressive update path turned on
Desktop Environment: Cinnamon
Video drivers: 64 bit, version 375.26 {tried} & 378.09 beta {currently running}. Both drivers has the same issue.
Problem: Screen tearing, most notable when doing full screen flash video, in Firefox, from sources such as Youtube or Crunchyroll.
CPU: haswell generation, and none of the cores ever get pinned at 100% while playing the video
RAM: 8GB
Kernel version: 4.4.0-62-generic
Edit:
Have attached:
nvidia-bug-report.log.gz
inxi -G | pastebin:
I am using the VGA output option on my card.
I have tried togging “force full composition Pipeline” on and off. I have tried swapping drivers to the new beta. I have tried a bunch of random possible fixes I found around the web, and nothing has helped.
If I have missed anything else, please let me know.
Edit2 :
I tried a clean install of Mint linux 17.3 with the cinnamon desktop. With specifically driver version 367.57 was the only time I didn’t see tearing {running the GT 730}. Although I did see other problems. The lines in screen tearing tests were now blurry, and almost had an odd shimmer to them. The faster the lines moved the more they’d blur and the more shimmery they’d get.
Tried using the integrated Intel video, and seen the same tearing problems {Mint 18.1}
Tried running driver version 367.57 in Mint 18.1 and still seen tearing. Although it appeared to be less so.
Tried many different kernels, and to some extent the amount of tearing changed, but it was always there.
Installed an Nvidia 970 GTX and seen tearing {mint 18.1, driver was 378.09}
Edit 3 :
Installed Open Suse tumbleweed – open source drivers had tearing. It wouldn’t connect to the repo so I couldn’t download the dependencies the proprietary driver installer needed.
Ubuntu 16.04.1 LTS – open source drivers didn’t have tearing, but had the same blurring and shimmering affect that Mint 17.3 had. Switched the driver with the build in driver manager to 367.57, as this is the Ubuntu recommended driver, and the tearing was back.
nvidia-bug-report.log.gz (122 KB)
