Can anyone shed any light on the support of the following configuration:
RHEL Linux 4, x86_64
CUDA 2.0
GeForce 9800
Supported configs don’t seem to be well documented on the Nvidia site. If you go to the driver page, there is no Linux support listed at all for GeForce 9. However, there appears to be a beta 173.08 driver with the needed support:
I can confirm, I’m currently running CUDA 2.0b on CentOS 5 with a 9800GTX.
CUDA works alsmost perfectly without any tweaking involved (only doesn’t recognise the full card name and reports the code name “G92-420” instead of the full product name “9800 GTX” like previous versions did).
Note that my server is text-mode only (only a plain simple PCI card running a text terminal just in case we need some local access). There’s no Xserver at all and the GeForce isn’t connected to a monitor (to avoid the execution time limit, and in general to avoid any external disturbance to the running kernel that may arise from a concurrent graphic display), so I can’t assert if 3D is working with that hardware/driver combination.
Also the nice thing in this configuration is that the 2.0b SDK has separate libraries without (libcutil) and with(libparamgl) dependencies on Xorg. (Whereas everything was in libcutil in previous versions, although it was still possible to obtain a non-Xorg-dependent libcutil). Which makes it easier to compile CUDA code on a machine without Xorg.
