Check with developer to make sure GeforceNow works with this version of macOS. You may need to reinstall the application. Be sure to install any available updates for the application and macOS.
Process: GeForceNOW [1846]
Path: /Applications/GeForceNOW.app/Contents/MacOS/GeForceNOW
Identifier: com.nvidia.gfnpc.mall
Version: 2.0.12.60 (2.0.12.60)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: GeForceNOW [1846]
User ID: 501
Date/Time: 2019-09-28 13:44:53.385 -0700
OS Version: Mac OS X 10.14.6 (18G103)
Report Version: 12
Anonymous UUID: 35D895F8-BCE1-5600-5778-C08A7DBEE7EB
Time Awake Since Boot: 1500 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @executable_path/…/Frameworks/libGeronimo.dylib
Referenced from: /Applications/GeForceNOW.app/Contents/MacOS/GeForceNOW
Reason: image not found
Binary Images:
0x1050b6000 - 0x1051a5ffb +com.nvidia.gfnpc.mall (2.0.12.60 - 2.0.12.60) /Applications/GeForceNOW.app/Contents/MacOS/GeForceNOW
0x1146fc000 - 0x11476670f dyld (655.1.1) /usr/lib/dyld
0x7fff4bad8000 - 0x7fff4c88dffb com.apple.AppKit (6.9 - 1671.60.109) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff4dc4c000 - 0x7fff4dc4cfff com.apple.Cocoa (6.11 - 23) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff4df35000 - 0x7fff4dfbbfff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <1E8E64E6-0E58-375A-97F7-07CB4EE181AC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff4f5b6000 - 0x7fff4f6bafff com.apple.CoreMedia (1.0 - 2290.13) /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff4f717000 - 0x7fff4f717fff com.apple.CoreServices (946 - 946) <2EB6117A-6389-311B-95A0-7DE32C5FCFE2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff50252000 - 0x7fff50292ff3 com.apple.CoreVideo (1.8 - 281.4) <10CF8E52-07E3-382B-8091-2CEEEFFA69B4> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff50579000 - 0x7fff5057effb com.apple.DiskArbitration (2.7 - 2.7) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff50dfc000 - 0x7fff50e8bfff com.apple.framework.IOKit (2.0.2 - 1483.260.4) <8A90F547-86EF-3DFB-92FE-0E2C0376DD84> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff50e8d000 - 0x7fff50e9cffb com.apple.IOSurface (255.6.1 - 255.6.1) <85F85EBB-EA59-3A8B-B3EB-7C20F3CC77AE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff58152000 - 0x7fff58161ffb com.apple.opengl (17.7.3 - 17.7.3) <94B5CF34-5BD6-3652-9A8C-E9C56E0A9FB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff599f1000 - 0x7fff59cf1fff com.apple.security (7.0 - 58286.270.3.0.1) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff5a14d000 - 0x7fff5a1bafff com.apple.SystemConfiguration (1.17 - 1.17) <30C8327F-3EFF-3520-9C50-016F8B6B954F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff5a419000 - 0x7fff5a77afff com.apple.VideoToolbox (1.0 - 2290.13) <7FCB2FC0-EFB8-37C2-B0D3-60AE9FDFE230> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff77439000 - 0x7fff7743affb libSystem.B.dylib (1252.250.1) /usr/lib/libSystem.B.dylib
Model: MacBookPro11,2, BootROM 156.0.0.0.0, 4 processors, Intel Core i7, 2.5 GHz, 16 GB, SMC 2.18f15
Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.61.2 AirPortDriverBrcmNIC-1305.8)
Bluetooth: Version 6.0.14d3, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 2.0 Hub
USB Device: USB Optical Mouse
USB Device: Saitek Eclipse Keyboard
USB Device: USB 2.0 Camera
USB Device: USB Audio Device
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
