GET3D Initialization
Hello all,
I am aiming to use the NVIDIA GET 3D Research model, but it requires CUDA v 11.0. I have secured a NVIDIA Geforce RTX 2070 Super and installed the driver, but it appears the driver is compatible with CUDA 12.4. Can someone please link me the driver that is compatible with CUDA 11.0 and NVIDIA GPU Geforce RTX 2070 Super? Thank you
Drivers are backwards compatible, (within reason), with older versions of Cuda, so you should not have a problem using the current driver, unless software requirements dictate a specific driver version.
