Hello, when pulling docker from nvtltea/med, I met following errors (login succeeded)
:~$ sudo docker login nvcr.io
Authenticating with existing credentials…
WARNING! Your password will be stored unencrypted in /home//.docker/config.json.
Configure a credential helper to remove this warning. See
docker login | Docker Documentation
Login Succeeded
***:~$ sudo docker pull nvcr.io/nvtltea/med/tlt-annotate:v0.1-py3
Error response from daemon: pull access denied for nvcr.io/nvtltea/med/tlt-annotate, repository does not exist or may require ‘docker login’
It would be greate that you could offer some help to solve this issue.
For your information, in the ‘Transfer-Learning-Toolkit-Medical-Imaging-Getting-Started-Guide_EA (1).pdf’, ‘Set Your Organization’ is needed before ‘Get API Key’.
However in my process, ‘Set Your Organization’ dialog didn’t pop up, so I didn’t set organization as ‘nvtltea/med’. Is this the reason of download failure? If yes, how could I set organization as ‘nvtltea/med’?
