Hi there,
I am having no success in trying to get the e-con System camera to work with the detectnet-camera application. I have changed the #DEFINE from -1 to 0 to indicate third party camera.
I have managed to get the camera to work using the demo program from e-con systems as well as the e-con systems gstreamer example. This camera uses UYVY format.
Not sure if anyone else has successfully gotten detectnet-camera working with an e-con system camera. If you have, would love to hear what’s required. (Or if you have other suggestions on how to proceed).
Thanks in advance.
jetson_inference use GStreamer to open the camera source.
Could you try to run this command on the console first?
[url]https://github.com/dusty-nv/jetson-utils/blob/4e94fb28d33b131bd03300810bd52f3abe28659b/camera/gstCamera.cpp#L353[/url]
thanks for the reply.
I spent a cozy afternoon with the GStreamer docs and figured it out. I reworked the GStreamer string and now all is well.
For anyone else interested, this is the change I made;
In line 351 of gstCamera.cpp (Jetpack 3.3 version);
ss << "v4l2src /dev/video" << mV4L2Device << " ! ";
ss << "video/x-raw, format=(string)UYVY, width=(int)" << mWidth;
ss << ", height=(int)" << mHeight;
ss << " ! videoconvert ! video/x-raw, formatRGB, width=(int)" << mWidth;
ss << ", height=(int)" << mHeight << ", ! appsink name=mysink";
(NOTE: I retyped that and didn’t copy/paste from the actual code, so hopefully no syntax errors in there).
