GLFW plugin error, after using set_joint_position_target function in python
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: 4080 super
  • Driver Version: 575
Topic Description
Detailed Description
I’m reading 12 dynamixel motors directly through python script .
currently environment is : Docker container → Isaac sim → headless mode-> it reads my repository files my python code , and USD( urdf, other assets)
After my asset interacts with other asset(Groot 1), using function set_joint_position_target, it kept showed GLFW initialization failure below.
DXL zero captured (first good frame).
2025-09-16 07:14:13 [24,653ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-09-16 07:14:13 [24,653ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.5]) (impl: carb.windowing-glfw.plugin)
[24.740s] Simulation App Shutting Down
I changed closing headless mode, connected display on docker container / local isaacsim, either way it shows same error.
Using function set_joint_position(q) works well, but as soon as it interacts wit other asset, it explodes.
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Steps to Reproduce
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
@jayahn i am just another user, but would it be possible to upload the latest log in its entirety? it could be something else that’s causing the crash. per the official doc, the GLFW initialization failed warning can be ignored when running headless -
so i was thinking there are some other information from the log that could help troubleshoot the crash.
