How am i supposed to drive this pin using the Jetson GPIO library? I am using a custom carrier board so I am not able to directly use the gpio pin header numbers. I am able to drive the pin using “echo 1 > PAC.06/value” however I would prefer a python script.
As the documentation says I can use the TEGRA_SOC names to drive this pin, however when I use the signal name “GPIO09” I get a ValueError: Channel GPIO09 is invalid Ive also tried GPIO3_PAC.06 but this also gives the same result.
Which string do I need to use to drive this pin?
