On a Thinkpad T490 with an MX250, the GPU Max Operating Temp is set to 57 Celsius degrees, causing it to throttle even at idle.
The solution that worked for T14 did not work.
On Windows, the throttle temperature could be raised to 94 degrees using ASUS GPU TweakII, but no effective means was found on Linux.
Is there any way to raise the it?
I am not good at English. Please forgive me.
