Graph composer installation issue
• Ubuntu 22.04.5
• DeepStream 7.1
• TensorRT Version 10.3.0.26-1+cuda12.5
• NVIDIA GPU Driver Driver Version: 560.35.03
• Could not install graph composer
• How to reproduce the issue ? run sudo dpkg -i graph_composer-4.1.0_x86_64.deb
shows this output:
user@user-Default-string:~/gxf_and_gc_v4.1.0$ sudo dpkg -i graph_composer-4.1.0_x86_64.deb
(Reading database ... 205749 files and directories currently installed.)
Preparing to unpack graph_composer-4.1.0_x86_64.deb ...
Unpacking graph-composer (4.1.0) over (4.1.0) ...
dpkg: dependency problems prevent configuration of graph-composer:
 graph-composer depends on rsync (= 3.2.7-0ubuntu0.22.04.2); however:
  Version of rsync on system is 3.2.7-0ubuntu0.22.04.4.
dpkg: error processing package graph-composer (--install):
 dependency problems - leaving unconfigured
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu3) ...
Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
Errors were encountered while processing:
 graph-composer
is it possible to install without manually downgrading rsync version?
Seems no.
You can download deb package from https://launchpad.net/~ubuntu-security-proposed/+archive/ubuntu/ppa/+build/25628106/+files/rsync_3.2.7-0ubuntu0.22.04.2_amd64.deb and install it.
