When I installed the gripper on the robot, I started the simulation and the robot started swinging inexplicably. Below is the usd file of my robot and gripper.
mycobot_280_m5.zip (4.9 MB)
The first step here is to check the mass of each of your rigid bodies. If the masses are estimated, it is best to replace that with a realistic mass value.
Thanks, I’ve solved the problem.
Here’s the solution:
Related topics
| Assemble error | 2 | 203 | September 18, 2024 | |
| Unstable robot assembler in isaac sim 4.5 | 28 | 1235 | July 18, 2025 | |
| Incorrect robot mass? | 6 | 2022 | November 23, 2021 | |
| Asset improvement request: robotiq 2f-140 | 12 | 485 | October 2, 2025 | |
| About isaac sim 2023.1.1 crash bug on robotic arm,Invalid for collision grabbing | 5 | 498 | June 27, 2024 | |
| Robot Assembler does not work for UR5e and Robotiq 2F 85 | 6 | 645 | July 18, 2025 | |
| Programmatically attaching joint via robot assembler | 3 | 818 | April 4, 2025 | |
| Robot Assembling issue (Ur5e hand with Robotiq Hand E gripper) | 3 | 363 | July 11, 2025 | |
| Unable to join Panda arm and Robotiq-2f-140 gripper, parallel gripper | 4 | 313 | April 9, 2025 | |
| Fixed joint slipping when assembling gripper with manipulator | 0 | 152 | July 24, 2024 |
