You shouldn’t have done that, it was only meant for @j22gim’s system to clean up runfile installer issues not related to the bug.
I guess Ubuntu meanwhile introduced an additional check in Software&Updates to detect an earlier runfile install. Please try to install it manually running
sudo apt install nvidia-driver-535
2) run the runfile installer for 535.113.01 with option -b. No rebooting.
The file I used is NVIDIA-Linux-x86_64-535.113.01.run. After checking that it is executable, I used this command in the terminal: sudo ./NVIDIA-Linux-x86_64-535.113.01.run -b
To which I found this error:
ERROR: An NVIDIA kernel module 'nvidia-drm' appears to already be loaded in your kernel. This may be because it is in use (for example, by an X server, a CUDA program, or the NVIDIA
Persistence Daemon), but this may also happen if your kernel was configured without support for module unloading. Please be sure to exit any programs that may be using the
GPU(s) before attempting to upgrade your driver. If no GPU-based programs are running, you know that your kernel supports module unloading, and you still receive this message,
then an error may have occurred that has corrupted an NVIDIA kernel module's usage count, for which the simplest remedy is to reboot your computer.
After pressing OK:
ERROR: Installation has failed. Please see the file "/var/log/nvidia-installer.log" for details. You may find suggestions on fixing installation problems in the README available on
the Linux driver download page at www.nvidia.com.
However my 2nd display is working fine so I would prefer not to touch anything except that you have a strong reason to.
I include the new log file in case it is of help to diagnose the problem: nvidia-bug-report.log.gz (158.1 KB)
Just to be cautious from now on, what is the next step? I guess I should wait until a newer driver is released (newer that the 545.23.06 BETA, which also didn’t work for me), and then try again. If it doesn’t work, I can always come back to the current 525 I’m using now, sounds good?
I also have seen that I seem to have several drivers in my system.
This is the output of the command dpkg -l |grep nvidia
ii libnvidia-cfg1-525:amd64 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-525 525.125.06-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-525:amd64 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-525:i386 525.125.06-0ubuntu0.22.04.1 i386 NVIDIA libcompute package
rc libnvidia-compute-535:amd64 535.113.01-0ubuntu0.22.04.3 amd64 NVIDIA libcompute package
rc libnvidia-compute-545:amd64 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA libcompute package
ii libnvidia-decode-525:amd64 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-525:i386 525.125.06-0ubuntu0.22.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.9-1.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-525:amd64 525.125.06-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-525:i386 525.125.06-0ubuntu0.22.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-525:amd64 525.125.06-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-525:amd64 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-525:i386 525.125.06-0ubuntu0.22.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-525:amd64 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-525:i386 525.125.06-0ubuntu0.22.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc linux-modules-nvidia-525-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35
rc linux-modules-nvidia-535-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35
rc linux-modules-nvidia-535-open-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35
ii linux-objects-nvidia-525-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35 (objects)
ii linux-objects-nvidia-535-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35 (objects)
ii linux-signatures-nvidia-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel signatures for nvidia modules for version 6.2.0-35-generic
ii nvidia-compute-utils-525 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-535 535.113.01-0ubuntu0.22.04.3 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA compute utilities
ii nvidia-dkms-525 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
rc nvidia-dkms-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA DKMS package
ii nvidia-driver-525 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-525 525.125.06-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-535 535.113.01-0ubuntu0.22.04.3 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-525 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-525 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-525 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
What should I do to clean this up? (or, just leave it as is?
ii libnvidia-cfg1-545:amd64 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-545 545.23.06-0ubuntu0~gpu22.04.3 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-525:amd64 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-545:amd64 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA libcompute package
ii libnvidia-compute-545:i386 545.23.06-0ubuntu0~gpu22.04.3 i386 NVIDIA libcompute package
ii libnvidia-decode-545:amd64 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-545:i386 545.23.06-0ubuntu0~gpu22.04.3 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-545:amd64 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-545:i386 545.23.06-0ubuntu0~gpu22.04.3 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-545:amd64 545.23.06-0ubuntu0~gpu22.04.3 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-545:amd64 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-545:i386 545.23.06-0ubuntu0~gpu22.04.3 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-545:amd64 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-545:i386 545.23.06-0ubuntu0~gpu22.04.3 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc nvidia-compute-utils-525 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA compute utilities
rc nvidia-dkms-525 525.125.06-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-dkms-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA DKMS package
ii nvidia-driver-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA driver metapackage
ii nvidia-firmware-545-545.23.06 545.23.06-0ubuntu0~gpu22.04.3 amd64 Firmware files used by the kernel module
rc nvidia-kernel-common-525 525.125.06-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA kernel source package
ii nvidia-utils-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA driver support binaries
ii xserver-xorg-video-nvidia-545 545.23.06-0ubuntu0~gpu22.04.3 amd64 NVIDIA binary Xorg driver
ii libnvidia-cfg1-545:amd64 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-545 545.29.06-0ubuntu0~gpu22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-545:amd64 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-545:i386 545.29.06-0ubuntu0~gpu22.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-545:amd64 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-545:i386 545.29.06-0ubuntu0~gpu22.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-545:amd64 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-545:i386 545.29.06-0ubuntu0~gpu22.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-545:amd64 545.29.06-0ubuntu0~gpu22.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-545:amd64 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-545:i386 545.29.06-0ubuntu0~gpu22.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-545:amd64 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-545:i386 545.29.06-0ubuntu0~gpu22.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc linux-objects-nvidia-525-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35 (objects)
rc linux-objects-nvidia-535-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35 (objects)
ii nvidia-compute-utils-545 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-545 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-545 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA driver metapackage
ii nvidia-firmware-545-545.29.06 545.29.06-0ubuntu0~gpu22.04.1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-545 545.29.06-0ubuntu0~gpu22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-545 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA kernel source package
ii nvidia-utils-545 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA driver support binaries
ii xserver-xorg-video-nvidia-545 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA binary Xorg driver
I now also have this problem, and driver version 525 does not appear in software & updates. Please may I have some help? I’ve switched to Nouveau for the time being.
edit 1: how do i uninstall my graphics card drivers, it won’t let me change back
edit 2: it seems updating to latest (570) fixed it. ill leave this here for any people coming to this thread in the future
edit 3: that worked for a time but then didn’t anymore :[
