Hello.
I have a Jetson Tx2 4Gb. I am trying to flash it for the first time using the SDK Developer. The Jetson Tx2 4Gb is plugged to the computer with an Ethernet cable and a Micro-USB cable. I try to type a username and password for my Jetson Tx2 4Gb but it says “Incorrect username or password”. I checked the terminal with the “dmesg” command. It gave errors (You can check them under this text) and at this point I don’t know what to do. What I want to do is flash my Jetson Tx2 4gb and start working on projects with it. Please help!
[ 45.743652] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 45.743656] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 45.743658] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 45.746489] wlp2s0: send auth to c4:71:54:5e:bf:ea (try 1/3)
[ 45.756281] wlp2s0: authenticated
[ 45.760098] wlp2s0: associate with c4:71:54:5e:bf:ea (try 1/3)
[ 45.772103] wlp2s0: RX AssocResp from c4:71:54:5e:bf:ea (capab=0x411 status=0 aid=3)
[ 45.774538] wlp2s0: associated
[ 45.884480] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 50.681675] r8169 0000:03:00.0 enp3s0: link up
[ 50.681684] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 50.908720] amdgpu: [powerplay] VI should always have 2 performance levels
[ 50.954609] amdgpu 0000:01:00.0: GPU pci config reset
[ 56.171263] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 56.171274] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 56.171284] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 56.171291] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 58.014746] [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 58.022654] amdgpu: [powerplay] can’t get the mac of 5
[ 58.946084] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 58.946097] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 58.946108] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 58.946115] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 60.554739] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 60.554753] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 60.554764] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 60.554771] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 60.997954] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 60.997961] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 60.997967] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 60.997970] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 61.797996] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 61.798001] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 61.798005] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 61.798007] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 62.004680] rfkill: input handler disabled
[ 63.555469] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 63.555475] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 63.555478] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 63.555480] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 63.971892] amdgpu: [powerplay] VI should always have 2 performance levels
[ 64.014438] amdgpu 0000:01:00.0: GPU pci config reset
[ 65.583428] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 65.583446] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 65.583464] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 65.583477] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 71.133928] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 71.133933] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 71.133937] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 71.133939] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 74.959896] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 74.959901] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 74.959906] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 74.959908] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 97.832149] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 97.832154] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 97.832158] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 97.832161] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 162.104698] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 162.104710] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 162.104721] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 162.104755] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 270.870030] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 270.870035] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 270.870039] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 270.870042] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 271.697866] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 271.697872] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 271.697877] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 271.697881] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 272.785802] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 272.785809] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 272.785814] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 272.785818] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 279.509038] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 279.509045] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 279.509050] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 279.509053] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 288.212084] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 288.212091] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 288.212096] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 288.212099] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 290.319670] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 290.319677] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 290.319682] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 290.319686] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 306.137825] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 306.137832] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 306.137836] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 306.137839] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 340.973403] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 340.973409] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 340.973415] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 340.973418] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 369.966567] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 369.966575] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 369.966582] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 369.966588] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 425.977041] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 425.977046] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 425.977050] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 425.977052] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 443.390603] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 443.390610] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 443.390617] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 443.390620] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 532.036020] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 532.036026] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 532.036031] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 532.036034] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 537.085643] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 537.085648] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 537.085651] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 537.085654] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 546.615653] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 546.615661] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 546.615666] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 546.615668] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 575.486501] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 575.486507] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 575.486513] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 575.486517] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 616.979061] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 616.979066] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 616.979070] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 616.979072] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 701.695921] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 701.695933] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 701.695945] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 701.695952] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
[ 709.983534] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 709.983568] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 709.983573] pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
[ 709.983595] pcieport 0000:00:1c.4: [ 0] Receiver Error (First)
