I am trying to feed the HDMI output of the FLIR Duo camera into the Jetson TX2. The most affordable solution I have found so far was to use an HDMI-to-USB3 converter. Although the weight of it might be the down side. Another obstacle is the fact that the Jetson runs on Linux, so I’m not sure of the compatibility of the video grabbers with that operating system.
Has anyone ever done this with the FLIR Duo or any other HDMI-output cameras?
FLIR Duo: Support for FLIR Duo | Teledyne FLIR
HDMI-to-USB3 Converter: Amazon.com
Any suggestions would help greatly.
Sincerely,
Krystian Tomczuk
Hi Krystian,
I have connected the Flir Duo with the Jetson Nano via an HDMI to USB3 adapter, see images.
Google: if-link Video Capture-HDMI to USB 3
At the moment it is not available.
With
sudo apt-get install v4l-utils
v4l2-ctl --list-formats-ext -d /dev/video1
you will see something like the output below:
Now you can choose one of the resolutions.
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Size: Discrete 1920x1080
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1280x1024
Also I have connected a Flir Vue and a Sony RX0 with two of this devices, see images.
Best regards,
Wilhelm
