There are 499ohms pulldown resistor along with chokes in the Carrier Board design for Xavier AGX, connected to a FET. I’m designing a carrier board with the SoM and for HDMI output, I’m using a Redriver IC for the same. The re-driver IC (DS16EV5110ASQE/NOPB) is from Texas instruments and my doubt is, where should I place the pulldowns, after or before the re-driver IC.
Welcome to the NVIDIA Developer forums! Your issue is not related to Nsight Systems. I will move your topic to the Jetson Xavier category so the right folks have visibility.
Best,
Tom
Better to put the PD circuit to module side.
