I need tar file install packages for Linux arm
For Jetson platform, you need to use JetPack to install the corresponding TensorRT version.
Thanks a lot, after JetPack was installed, the device could not be booted,any solution for this? Or can I install tensorRT without using JetPack?
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
So the current problem is device can’t boot, is there any log? which JetPack version you installed?
