I am getting occasional flickering and screen corruption after upgrading my system to Debian/Wheezy/GNOME 3 with latest Nvidia drivers and Linux kernel. The screen corruption goes away after moving windows around but sometimes it also causes font corruption in programs like gnome-terminal, gedit and other programs that does not go away unless I change the font. There is no apparent trigger but it only is happening when I am actually using the computer. I have a nvidia-bug-report.log.gz but don’t see an option to post it. Please advise.
Here is excerpt of the debug log:
[ 5328.817] (II) NVIDIA(GPU-0): “640x480_60” : 640 x 480 @ 59.9 Hz (from: EDID)
[ 5328.817] (II) NVIDIA(GPU-0): — End of ModePool for NEC LCD1980FXi (DFP-0): —
[ 5632.406] (II) NVIDIA(0): The NVIDIA X driver has encountered an error; attempting to
[ 5632.406] (II) NVIDIA(0): recover…
[ 5632.436] [mi] EQ overflowing. Additional events will be discarded until existing events are processed.
[ 5632.436]
[ 5632.436] Backtrace:
[ 5632.437] 0: /usr/bin/Xorg (xorg_backtrace+0x49) [0xb7725769]
[ 5632.437] 1: /usr/bin/Xorg (mieqEnqueue+0x22b) [0xb770405b]
[ 5632.437] 2: /usr/bin/Xorg (0xb75a8000+0x51405) [0xb75f9405]
[ 5632.437] 3: /usr/bin/Xorg (xf86PostMotionEventM+0x24b) [0xb763356b]
[ 5632.437] 4: /usr/lib/xorg/modules/input/evdev_drv.so (0xb4deb000+0x35ad) [0xb4dee5ad]
[ 5632.437] 5: /usr/lib/xorg/modules/input/evdev_drv.so (0xb4deb000+0x4a2c) [0xb4defa2c]
[ 5632.437] 6: /usr/bin/Xorg (0xb75a8000+0x7ac01) [0xb7622c01]
[ 5632.437] 7: /usr/bin/Xorg (0xb75a8000+0xa094a) [0xb764894a]
[ 5632.437] 8: (vdso) (__kernel_sigreturn+0x0) [0xb7589400]
[ 5632.437] 9: /usr/bin/Xorg (0xb75a8000+0x181650) [0xb7729650]
[ 5632.437] 10: (vdso) (__kernel_sigreturn+0x0) [0xb7589400]
[ 5632.437] 11: (vdso) (__kernel_vsyscall+0x10) [0xb7589424]
[ 5632.437] 12: /lib/i386-linux-gnu/i686/cmov/libc.so.6 (ioctl+0x19) [0xb72e4a99]
[ 5632.437] 13: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0xb4651000+0x10185e) [0xb475285e]
[ 5632.438] 14: ?? [0xe0010000]
[ 5632.438]
[ 5632.438] [mi] These backtraces from mieqEnqueue may point to a culprit higher up the stack.
[ 5632.438] [mi] mieq is NOT the cause. It is a victim.
[ 5632.455] (II) NVIDIA(0): Error recovery was successful.
[ 5632.455] [mi] Increasing EQ size to 512 to prevent dropped events.
[ 5632.456] [mi] EQ processing has resumed after 5 dropped events.
[ 5632.456] [mi] This may be caused my a misbehaving driver monopolizing the server’s resources.
[ 5678.348] (II) NVIDIA(0): The NVIDIA X driver has encountered an error; attempting to
[ 5678.348] (II) NVIDIA(0): recover…
[ 5678.374] (II) NVIDIA(0): Error recovery was successful.
[ 5727.336] (II) NVIDIA(0): The NVIDIA X driver has encountered an error; attempting to
[ 5727.336] (II) NVIDIA(0): recover…
[ 5727.363] (II) NVIDIA(0): Error recovery was successful.
I think I may have fixed the problem.
Boot config before:
linux /bzImage-3.9.1gwar_2013-05-09.2 ro root=/dev/mapper/raid_vg-root acpi_enforce_resources=lax
after:
linux /bzImage-3.9.1gwar_2013-05-09.2 ro root=/dev/mapper/raid_vg-root pci=nommconf
I will try restoring acpi_enforce_resources=lax eventually because otherwise I cannot use my sensors.
( cat kern.log kern.log.0 ; gzip -dc kern.log.*.gz ) | grep NVRM
May 15 07:32:38 gwar kernel: [475268.834462] NVRM: Xid (0000:05:00): 6, PE0000 07b0 ffedeceb 0000f03c 00270127 0008e400
May 15 07:40:57 gwar kernel: [475767.354340] NVRM: Xid (0000:05:00): 6, PE0000 0400 00000000 0000fd68 ffffffff ffffffff
May 15 07:59:31 gwar kernel: [476880.968035] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:00:29 gwar kernel: [476939.430692] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:00:39 gwar kernel: [476949.535228] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:01:03 gwar kernel: [476973.159910] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:01:38 gwar kernel: [477008.153385] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:02:46 gwar kernel: [477075.996867] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000fa3c ffffffff ffffffff
May 15 08:03:28 gwar kernel: [477118.443175] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:05:06 gwar kernel: [477216.775353] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:06:41 gwar kernel: [477311.460656] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:10:21 gwar kernel: [477531.536765] NVRM: os_pci_init_handle: invalid context!
May 15 08:10:21 gwar kernel: [477531.536772] NVRM: os_pci_init_handle: invalid context!
May 15 08:10:21 gwar kernel: [477531.536780] NVRM: os_pci_init_handle: invalid context!
May 15 08:11:21 gwar kernel: [477590.950779] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 00005e1c 00000000 ffd6d4d2
May 15 08:11:30 gwar kernel: [477600.767989] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:11:56 gwar kernel: [477625.953488] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:14:01 gwar kernel: [477751.688349] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:14:49 gwar kernel: [477799.864869] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:16:52 gwar kernel: [477922.363094] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:17:14 gwar kernel: [477944.672251] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:18:23 gwar kernel: [478013.160593] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c 003f3f3f 00b9b9b9
May 15 08:21:24 gwar kernel: [478194.019108] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c 003f3f3f 00b9b9b9
May 15 08:23:10 gwar kernel: [478299.953617] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:25:35 gwar kernel: [478444.968806] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:27:11 gwar kernel: [478541.351483] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:27:45 gwar kernel: [478575.648628] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:27:51 gwar kernel: [478581.187950] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:31:14 gwar kernel: [478784.502915] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:32:26 gwar kernel: [478856.323164] NVRM: Xid (0000:05:00): 6, PE0000 1000 ffe9e8e7 0000f03c ffe9e8e7 ffe9e8e7
May 15 08:32:30 gwar kernel: [478860.253663] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:33:52 gwar kernel: [478942.218440] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:36:09 gwar kernel: [479079.932088] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:37:11 gwar kernel: [479141.736347] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:39:23 gwar kernel: [479273.344308] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:42:00 gwar kernel: [479430.137650] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:42:03 gwar kernel: [479433.035129] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:43:15 gwar kernel: [479505.637559] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:46:24 gwar kernel: [479694.654134] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:48:52 gwar kernel: [479842.782203] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:50:21 gwar kernel: [479931.661782] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:50:57 gwar kernel: [479967.886970] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 08:51:05 gwar kernel: [479975.571890] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:51:29 gwar kernel: [479999.928461] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:53:11 gwar kernel: [480101.357107] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:55:05 gwar kernel: [480215.673020] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:55:16 gwar kernel: [480226.295798] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 08:59:00 gwar kernel: [480450.593585] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:03:03 gwar kernel: [480693.698017] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ff1a1a1a
May 15 09:07:35 gwar kernel: [480965.325386] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 09:08:08 gwar kernel: [480998.902075] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 0000f03c ffffffff ffffffff
May 15 09:12:14 gwar kernel: [481244.723968] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:14:30 gwar kernel: [481380.739320] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:23:12 gwar kernel: [481902.669063] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:23:52 gwar kernel: [481942.657249] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:33:07 gwar kernel: [482497.052754] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000fd14 ffffffff ffffffff
May 15 09:33:07 gwar kernel: [482497.080298] NVRM: Xid (0000:05:00): 2, CCMDs 00000000 0000004d 00000184 ffffffff 00000001
May 15 09:35:58 gwar kernel: [482668.820799] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:37:36 gwar kernel: [482765.959768] NVRM: Xid (0000:05:00): 6, PE0000 0100 00000006 0000c3f8 00000000 00000000
May 15 09:37:46 gwar kernel: [482776.628718] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:43:01 gwar kernel: [483091.745908] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:43:32 gwar kernel: [483122.734902] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000fd2c ffffffff ffffffff
May 15 09:44:20 gwar kernel: [483170.824412] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:45:54 gwar kernel: [483264.734212] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:50:30 gwar kernel: [483540.851452] NVRM: Xid (0000:05:00): 12, COCOD 00000000 e0011900 00000019 00001c5c 00c8c8c8
May 15 09:51:44 gwar kernel: [483614.838882] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:51:48 gwar kernel: [483618.743443] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:54:46 gwar kernel: [483796.755264] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:57:01 gwar kernel: [483931.860669] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c ffffffff ffffffff
May 15 09:58:47 gwar kernel: [484037.774271] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f03c 003f3f3f 00b9b9b9
May 15 10:01:20 gwar kernel: [ 5.704157] NVRM: loading NVIDIA UNIX x86 Kernel Module 304.88 Wed Mar 27 14:31:12 PDT 2013
May 15 10:12:35 gwar kernel: [ 688.361617] NVRM: Xid (0000:05:00): 6, PE0000 0100 ffffffff 000086c8 00000000 9d3e9dd8
May 15 11:03:43 gwar kernel: [ 3756.997329] NVRM: Xid (0000:05:00): 6, PE0000 0a48 e5000000 0000fb68 e5000000 e5000000
May 15 11:34:56 gwar kernel: [ 5629.406860] NVRM: Xid (0000:05:00): 6, PE0000 0100 00000006 0000fde8 ffffffff 04afa600
May 15 11:35:45 gwar kernel: [ 5678.349839] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0067b524 ffffffff ffffffff
May 15 11:36:34 gwar kernel: [ 5727.336996] NVRM: Xid (0000:05:00): 6, PE0000 0400 00000000 0000ed90 ffffffff ffffffff
May 15 11:37:01 gwar kernel: [ 5754.348095] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0067b940 ffffffff ffffffff
May 15 11:54:23 gwar kernel: [ 6796.370117] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000fda4 ffffffff ffffffff
May 15 12:34:10 gwar kernel: [ 9183.485886] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000fdfc ffffffff ffffffff
May 15 12:34:10 gwar kernel: [ 9183.509955] NVRM: Xid (0000:05:00): 2, CCMDs 00000000 0000004d 00000184 ffffffff 00000001
May 15 12:35:49 gwar kernel: [ 9282.497195] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000fdfc ffffffff ffffffff
May 15 12:38:09 gwar kernel: [ 9422.407091] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000fdf4 ffffffff ffffffff
May 15 12:39:17 gwar kernel: [ 9490.319377] NVRM: Xid (0000:05:00): 6, PE0000 0fc8 ff202529 0000640c 00000000 ff23282c
May 15 12:40:10 gwar kernel: [ 9543.605328] NVRM: Xid (0000:05:00): 6, PE0000 08d0 ffffffff 001f7e88 ffffffff ffffffff
May 15 12:45:09 gwar kernel: [ 9842.424303] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000fddc ffffffff ffffffff
May 15 12:45:38 gwar kernel: [ 9871.426789] NVRM: Xid (0000:05:00): 6, PE0000 0970 ffa19d9a 0000f468 ffffffff ffffffff
May 15 13:54:20 gwar kernel: [ 5.717806] NVRM: loading NVIDIA UNIX x86 Kernel Module 304.88 Wed Mar 27 14:31:12 PDT 2013
May 13 19:49:59 gwar kernel: [346709.375289] NVRM: os_pci_init_handle: invalid context!
May 13 19:49:59 gwar kernel: [346709.375309] NVRM: os_pci_init_handle: invalid context!
May 13 19:49:59 gwar kernel: [346709.375316] NVRM: os_pci_init_handle: invalid context!
May 14 07:21:59 gwar kernel: [388229.138066] NVRM: os_pci_init_handle: invalid context!
May 14 07:21:59 gwar kernel: [388229.138073] NVRM: os_pci_init_handle: invalid context!
May 14 07:21:59 gwar kernel: [388229.138080] NVRM: os_pci_init_handle: invalid context!
May 14 07:34:02 gwar kernel: [388952.258162] NVRM: Xid (0000:05:00): 6, PE0000 0400 27130701 0000f03c 6a000000 00000000
May 14 07:39:57 gwar kernel: [389307.875284] NVRM: Xid (0000:05:00): 6, PE0000 0b28 ff49beea 00001fb8 00000000 ff49beea
May 14 07:47:43 gwar kernel: [389773.092410] NVRM: Xid (0000:05:00): 6, PE0000 1000 ffe8e7e6 000084a8 00000000 ffe8e7e6
May 14 07:50:08 gwar kernel: [389918.442844] NVRM: Xid (0000:05:00): 6, PE0000 1a14 01012000 0000fdf4 80ffff00 3d2b1d11
May 14 07:53:38 gwar kernel: [390128.444728] NVRM: os_pci_init_handle: invalid context!
May 14 07:53:38 gwar kernel: [390128.444736] NVRM: os_pci_init_handle: invalid context!
May 14 07:53:38 gwar kernel: [390128.444743] NVRM: os_pci_init_handle: invalid context!
May 14 08:12:33 gwar kernel: [391263.446314] NVRM: Xid (0000:05:00): 6, PE0000 0664 ffedeceb 0000b794 00000000 1d2b3d00
May 14 08:16:15 gwar kernel: [391485.431343] NVRM: Xid (0000:05:00): 6, PE0000 0960 00fefefe 00009e1c 00000000 00e1e6e5
May 14 12:50:09 gwar kernel: [407919.572758] NVRM: os_pci_init_handle: invalid context!
May 14 12:50:09 gwar kernel: [407919.572766] NVRM: os_pci_init_handle: invalid context!
May 12 09:54:03 gwar kernel: [224553.327129] NVRM: os_pci_init_handle: invalid context!
May 12 09:54:03 gwar kernel: [224553.327136] NVRM: os_pci_init_handle: invalid context!
May 12 09:54:08 gwar kernel: [224558.234191] NVRM: os_pci_init_handle: invalid context!
May 12 09:54:08 gwar kernel: [224558.234204] NVRM: os_pci_init_handle: invalid context!
May 12 09:54:08 gwar kernel: [224558.234212] NVRM: os_pci_init_handle: invalid context!
May 13 06:10:17 gwar kernel: [297527.661644] NVRM: Xid (0000:05:00): 6, PE0000 04f8 ffc3c6c3 0000fc98 ffd4d7d4 ffd4d7d4
May 13 06:27:29 gwar kernel: [298558.998237] NVRM: os_pci_init_handle: invalid context!
May 13 06:27:29 gwar kernel: [298558.998244] NVRM: os_pci_init_handle: invalid context!
May 13 06:27:29 gwar kernel: [298558.998252] NVRM: os_pci_init_handle: invalid context!
May 13 06:34:42 gwar kernel: [298992.023975] NVRM: os_pci_init_handle: invalid context!
May 13 06:34:42 gwar kernel: [298992.023990] NVRM: os_pci_init_handle: invalid context!
May 13 06:34:42 gwar kernel: [298992.023997] NVRM: os_pci_init_handle: invalid context!
May 13 06:37:06 gwar kernel: [299136.597403] NVRM: Xid (0000:05:00): 6, PE0000 1000 ffe9e8e7 0000549c 00000000 ffe8e7e6
May 11 23:39:23 gwar kernel: [187672.955280] NVRM: os_pci_init_handle: invalid context!
May 11 23:39:23 gwar kernel: [187672.955298] NVRM: os_pci_init_handle: invalid context!
May 11 23:39:23 gwar kernel: [187672.955305] NVRM: os_pci_init_handle: invalid context!
May 10 08:05:28 gwar kernel: [45238.751628] NVRM: os_pci_init_handle: invalid context!
May 10 08:05:28 gwar kernel: [45238.751635] NVRM: os_pci_init_handle: invalid context!
May 10 08:05:28 gwar kernel: [45238.751641] NVRM: os_pci_init_handle: invalid context!
May 10 15:27:15 gwar kernel: [71745.657776] NVRM: os_pci_init_handle: invalid context!
May 10 15:27:15 gwar kernel: [71745.657784] NVRM: os_pci_init_handle: invalid context!
May 10 15:27:15 gwar kernel: [71745.657789] NVRM: os_pci_init_handle: invalid context!
May 10 20:29:39 gwar kernel: [89889.382880] NVRM: os_pci_init_handle: invalid context!
May 10 20:29:39 gwar kernel: [89889.382894] NVRM: os_pci_init_handle: invalid context!
May 10 20:29:39 gwar kernel: [89889.382901] NVRM: os_pci_init_handle: invalid context!
May 10 22:34:02 gwar kernel: [97352.006265] NVRM: os_pci_init_handle: invalid context!
May 10 22:34:02 gwar kernel: [97352.006273] NVRM: os_pci_init_handle: invalid context!
May 10 22:34:02 gwar kernel: [97352.006280] NVRM: os_pci_init_handle: invalid context!
