I want to model the friction in a reduction gear.
I find CreateJointFrictionAttr().
But I cannot call in python script.
How can I use it?
Thank you.
How can I use it?
Thank you.
I find exts/omni.isaac.core/omni/isaac/core/articulations/articulation_view.py .
I could write code with that as a reference.
Example:
import omni.usd
from pxr import PhysxSchema
stage_handle = omni.usd.get_context().get_stage()
joint_prim_path = "/World/test_robot/base_link/left_wheel_joint"
joint_api = PhysxSchema.PhysxJointAPI(stage_handle.GetPrimAtPath(joints_prim_path))
joint_api.CreateJointFrictionAttr().Set(100.0)
