How can I enable "packet pacing" on connectX-5 ?
How can I enable “packet pacing” on the connectX-5 ? With the command ibv_devinfo -v I get Packet_pacing_caps: qp_rate_limits_max: 0kbps I expect here the wire rate of the card.
I’m running FW 16.23.1020 on an x512A with OFED.linux-4.4.2.0.70 driver.
Thanks Patrick
Hi Patrick,
Thank you for posting your question on the Mellanox Community.
Packet Pacing is support on the ConnectX-5 from firmware version 16.20.1010 and higher. You can use the following Mellanox Community Document to configure ‘Packet Pacing’-> https://community.mellanox.com/s/article/howto-configure-packet-pacing-on-connectx-4
Even though the document mentions only ConnectX-4, the ConnectX-5 uses the same driver.
If you experiencing any new issues after enabling ‘Packet Pacing’, please open a Mellanox Support Case by sending an email to support@mellanox.com mailto:support@mellanox.com
Thanks and regards,
~Mellanox Technical Support
