How can I use/edit the WebRTC extension to stream ONLY the camera?
https://docs.omniverse.nvidia.com/prod_extensions/prod_extensions/ext_livestream/webrtc.html
I can’t find the source code for the webrtc streaming and I want to stream ONLY what the camera is rendering, none of the rest of the application.
Hello @adammpolak! I’ve shared your post with the dev team for further assistance.
I wasn’t able to find usable source code either, but just in case this helps, you can click on the Folder Icon (Red) to see the python files that make up this extension. You can also click the Pencil Icon (Yellow) and open up the script in an IDE like Visual Studio.
This is terrific thank you, I will check those out and see if I can wrap my head around it.
