Is WebRTC extension broken for everyone?
Following the simple instructions here: WebRTC Browser Client — Omniverse Extensions latest documentation
When I navigate to the URL all I get is a grey block:
Not sure if these errors help:
2023-01-02 19:04:29 [Error] [carb.livestream-rtc.plugin] Stream Server: starting the server failed, 0x800B0000
2023-01-02 19:04:29 [Error] [carb.livestream-rtc.plugin] Could not initialize streaming components
2023-01-02 19:04:29 [Error] [carb.livestream-rtc.plugin] Couldn’t initialize the capture device.
Hi Adam,
As far as I can tell things are all good with the WebRTC streaming service. I am using it now in Create. The only difference I want you to try is not to use the “8011” port but “8111”
http://“server”:8111/streaming/webrtc-demo/?server=“server”
This seems to be an issue when you have the Audio2Face components enabled, the WebRTC does not load.
Hi Adam. What graphics driver version are you using? Dev team is thinking that you may need to update.
Thank you for the response. I am on version 516.94
For some reason audio2face webrtc won’t stream with this
Please try the latest Recommended/Certified driver: Driver 526.47 Compatibility Issues with Omniverse Apps
Same issue here, my driver version is: 525.85.05, on a double A10 GPU, couldn’t load WebRTC or Native streaming service, but websocket is fine in loading(but extremely slow)
