I’ve tried to using the RPi Camera with the Jetson TX2 through the CSI port of the J140 Carrierboard.
But whether they are connected or not, there is no “video” in /dev , like /dev/video0 or /dev/video1.
And I found the article like this :
that let me know Auvidea didn’t support the RPI camera for TX2 at 01/18/2018.
and this :
at that topic Auvidea said, at least, TX2 supports the RPI camera and also the developer kit camera (or only RPI cam).
Well, those make me confused So the Question is:
Is Auvidea J140 support the RPI camera for TX2 through CSI port? If so, how can I use it?
Is possible to use devkit camera with Auividea 140?
I want to use dev kit camera module but with only camera(Sunny Optical p5v27c?) without the board if possible.
I found that the camera is able to be detached from the ‘dev kit camera module’.
The camera has FFC 23p 0.3mm cable, and J140 has 22 pin 4 lane CSI-2 connector with 0.5mm pitch.
So would it possible to connect the camera(p5v27c) to J140 directly?
Would it work without setting some driver?
And can I get some adapter on web that can connect between the camera and J140?
Or is it easy to make the schematics of adapter FFC 23p 0.3mm to 22p 0.5mm? -
If Q.1 and Q.2 both are not supported with J140, Could you recommend some camera similar with RPI camera (not expensive, small, don’t have to have good performance) working with TX2&J140?
There are a lot of questions, but you don’t have to answer all of above, just explain to the best of your knowledge.
Thanks in advance :)
