Hi all!
I have been working with a USB camera on a JN30B carrier board from Auvidea.
I had to replace the camera and purchased an RPi v2.1 camera after seeing that the carrier board natively supports it.
The problem is that when I connect the camera to the CSI-CD port there is no video0 device coming up in /dev.
I do not know how else to check if the device is indeed connected and working. The camera is based on IMX219 and therefore the drivers should already be present.
FYI I use a 22 PIN to 15 PIN cable to connect the RPi camera.
Anyone came across this issue before?
Thank you in advance!
