When I try to install Revit connector on a Windows PC with an account that is not admini, the installation fails with the following error message
“An error occurred during the installation of Autodesk Revit: Command failed: “C:\Users\notbi_vm30byr\AppData\Local\ov\pkg\revit-connector-108.2.2228\RevitOmniSetup.exe” /INSTALL”
On the other hand, PC admini users can install Revit connector, but if you log in to PC with a non admini account, Omniverse conector will not load as an add-in for Revit, nor will Omniverse Launcher’s Revit connector does not appear in the library screen of the Omniverse Launcher.
How can we use Revit connector with a non admini account on my PC?
