I want to use Cortex-R5(SPE) directly access sysram to read or write data, so how can i do ?
pqy1010
1
kayccc
2
Please find the Jetson Sensor Processing Engine (SPE) Software Sources from download center: Jetson Download Center | NVIDIA Developer
Related topics
| If I flash SPE (Cortex-R5). How to write code with my jetson tx2? | 1 | 965 | August 23, 2019 | |
| The method using Cortex-R5 core and Sensor Processing System | 3 | 864 | July 24, 2023 | |
| Cortex R5 core and "Jetson Sensor Processing Engine (SPE)" on NX DevKit | 33 | 3779 | May 25, 2021 | |
| Cortex-R5 & FreeRTOS | 1 | 1140 | September 7, 2020 | |
| Use mmap access sysram is not working | 1 | 711 | April 27, 2021 | |
| Question with image size & debug uart | 1 | 850 | April 8, 2020 | |
| Jetson Sensor Processing Engine (SPE) Source Code | 3 | 341 | March 22, 2025 | |
| Jetson AGX Xavier SPE/Cortex-R5 Firmware Update | 5 | 1607 | May 14, 2020 | |
| Xavier integrates the core of cortex R5F, can all I/O be allocated to R5 for operation? | 1 | 634 | April 6, 2021 | |
| Debug AON SPE on AGX Orin | 5 | 374 | June 27, 2024 |
