I write a driver for camera. But I do not konw the parameter for the cmos.I do not have datasheet for the cmos.
I want print the mipi raw data, and I will analysis data to find the parameter.
Could you tell me how print the mipi raw data?
My error is:
nvidia@tegra-ubuntu:~$ ./v4l2_ctl.sh
[58849.860033] xiaolei --- ar0231_power_on: power on
[58849.902927] xiaolei --- ar0231_s_stream++,enable:1
[58849.907762] xiaolei --- ar0231_s_stream mode[0]
[58850.242930] tegra-vi4 15700000.vi: Status: 4 channel:00 frame:0079
[58850.249464] tegra-vi4 15700000.vi: timestamp sof 58855757449696 eof 58855779336448 data 0x02000040
[58850.259589] tegra-vi4 15700000.vi: capture_id 3 stream 0 vchan 0
VIDIOC_DQBUF: failed: Input/output error
[58851.218958] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[58852.222940] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
[58852.229866] xiaolei --- ar0231_s_stream++,enable:0
[58852.235255] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[58852.243712] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[58852.272577] xiaolei --- ar0231_power_off: power off
nvidia@tegra-ubuntu:~$ ./cat_debug.sh
# tracer: nop
# entries-in-buffer/entries-written: 26/26 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-2054 [000] ...1 58849.926777: rtos_queue_peek_from_isr_failed: tstamp:1839232448556 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58849.926784: rtcpu_start: tstamp:1839232451239
kworker/0:2-2054 [000] ...1 58849.926787: rtcpu_vinotify_handle_msg: tstamp:1839232505762 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:986502616 data:0x00000001
kworker/0:2-2054 [000] ...1 58850.082839: rtos_queue_peek_from_isr_failed: tstamp:1839237449947 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58850.238898: rtcpu_vinotify_handle_msg: tstamp:1839242421351 tag:CHANSEL_PXL_SOF channel:0x00 frame:121 vi_tstamp:996417615 data:0x00000001
kworker/0:2-2054 [000] ...1 58850.238918: rtcpu_vinotify_handle_msg: tstamp:1839242422659 tag:ATOMP_FS channel:0x00 frame:121 vi_tstamp:996417630 data:0x00000000
kworker/0:2-2054 [000] ...1 58850.238928: rtcpu_vinotify_handle_msg: tstamp:1839242436422 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:121 vi_tstamp:996432819 data:0x08000000
kworker/0:2-2054 [000] ...1 58850.238946: rtos_queue_peek_from_isr_failed: tstamp:1839242450735 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58850.290764: rtcpu_vinotify_handle_msg: tstamp:1839243105259 tag:CHANSEL_PXL_EOF channel:0x00 frame:121 vi_tstamp:997101456 data:0x01ff0002
kworker/0:2-2054 [000] ...1 58850.290766: rtcpu_vinotify_handle_msg: tstamp:1839243106269 tag:CHANSEL_FAULT channel:0x00 frame:121 vi_tstamp:997101576 data:0x02000040
kworker/0:2-2054 [000] ...1 58850.290766: rtcpu_vinotify_handle_msg: tstamp:1839243108007 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:121 vi_tstamp:997104143 data:0x08000000
kworker/0:2-2054 [000] ...1 58850.290767: rtcpu_vinotify_handle_msg: tstamp:1839243109014 tag:CHANSEL_FAULT_FE channel:0x01 frame:121 vi_tstamp:997104149 data:0x00000001
kworker/0:2-2054 [000] ...1 58850.290768: rtcpu_vinotify_handle_msg: tstamp:1839243110066 tag:ATOMP_FE channel:0x00 frame:121 vi_tstamp:997104149 data:0x00000000
kworker/0:2-2054 [000] ...1 58850.394767: rtos_queue_peek_from_isr_failed: tstamp:1839247450460 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58850.550856: rtos_queue_peek_from_isr_failed: tstamp:1839252451460 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58850.706843: rtos_queue_peek_from_isr_failed: tstamp:1839257451963 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58850.862854: rtos_queue_peek_from_isr_failed: tstamp:1839262452472 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58851.070831: rtos_queue_peek_from_isr_failed: tstamp:1839267452982 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58851.226880: rtos_queue_peek_from_isr_failed: tstamp:1839272453485 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58851.382852: rtos_queue_peek_from_isr_failed: tstamp:1839277453991 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58851.538885: rtos_queue_peek_from_isr_failed: tstamp:1839282454498 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58851.694831: rtos_queue_peek_from_isr_failed: tstamp:1839287455007 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58851.850888: rtos_queue_peek_from_isr_failed: tstamp:1839292455516 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58852.006842: rtos_queue_peek_from_isr_failed: tstamp:1839297456025 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58852.162830: rtos_queue_peek_from_isr_failed: tstamp:1839302456534 queue:0x0b4a3c58
kworker/0:2-2054 [000] ...1 58852.267095: rtos_queue_peek_from_isr_failed: tstamp:1839305209822 queue:0x0b4a3c58
nvidia@tegra-ubuntu:~$ v4l2-ctl --all
[58891.258551] xiaolei --- ar0231_power_on: power on
Driver Info (not using libv4l2):
Driver name : tegra-video
Card ty[58891.283185] xiaolei --- ar0231_power_off: power off
pe : vi-output, ar0231 1-006a
Bus info : platform:15700000.vi:0
Driver version: 4.4.38
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: no power)
Format Video Capture:
Width/Height : 1280/512
Pixel Format : 'YUYV'
Field : None
Bytes per Line : 2560
Size Image : 1310720
Colorspace : sRGB
Transfer Function : Default
YCbCr Encoding : Default
Quantization : Default
Flags :
Camera Controls
frame_length (int) : min=1522 max=15520 step=1 default=1522 value=1522 flags=slider
coarse_time (int) : min=5 max=15510 step=1 default=1512 value=1512 flags=slider
coarse_time_short (int) : min=5 max=15510 step=1 default=1512 value=1512 flags=slider
group_hold (intmenu): min=0 max=1 default=0 value=0
hdr_enable (intmenu): min=0 max=1 default=0 value=0
gain (int) : min=1 max=48 step=1 default=1 value=1 flags=slider
bypass_mode (intmenu): min=0 max=1 default=0 value=0
override_enable (intmenu): min=0 max=1 default=0 value=0
height_align (int) : min=1 max=16 step=1 default=1 value=1
size_align (intmenu): min=0 max=2 default=0 value=0
write_isp_format (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_modes (int) : min=0 max=30 step=1 default=30 value=1 flags=read-only
