We need to use gStreamer to encode the camera image to H.265 video, . gStreamer is not current supported in DriveAGX orin, how to add it to Drive AGX Orin platform?
Hello @sean.chen3,
I believe you need to use DriveWorks SDK.
For instance, this sample app shows you how to capture from a camera, encode the stream and store it into a file. You can later adapt it for streaming.
Please let us know if you need any help with that, we would be glad to assist you.
regards,
Andrew
Hi Andrew,
Thanks for the quick response. Is that possible to recompile the gSteamer source code and integrate that into DriveOS?
Regards,
Sean
This is DRIVE Orin platform related issue, please open your issue at DRIVE AGX Orin forum to get the support.
Latest DRIVE AGX Orin/DRIVE AGX Orin General topics - NVIDIA Developer Forums
