How to add gStreamer to Drive AGX Orin platform running DriveOS 6.0.8.1?
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
We need to use gStreamer to process the camera image. However gStreamer is not current supported in Drive OS on DRIVE AGX Orin. How can I add gStreamer to Drive AGX Orin platform with DriveOS 6.0.8.1? Is that possible to recompile the gSteamer source code and integrate that into DriveOS?
Dear @sean.chen3,
Updated the topic description (removed unneeded sections).
Yes. gstreamer is not supported on DRIVE.
May I know your complete use case to provide better guidance.
Hi Siva,
There is an existing application using gStreamer for Camera pipeline process on Jetson Orin platform that needs to be ported to the DriveOrin platform. Is that possible to have the Jetson Nvidia nvv4l2 / gSteamer plug-in added to DriveOrin?
Thanks,
Sean
Dear @sean.chen3,
As clarified, gstreamer is not a supported feature on DRIVE. What is the functionality you are looking for like encoding/decoding etc?
I have the same problem.
I have cross-compiled a version of gstreamer and copied it to the board, but I cannot get the NVIDIA GStreamer plugin libraries for the board.
Hi Siva,
We want to port an application that use gStreamer pipeline to encode camera capture output to H.26x video, and decode back to RGB. Is there a way to port the Nvidia Jetson Orin gStreamer plug-in to Drive Orin platform?
Dear @sean.chen3 ,
We recommend to use NVMedia APIs for camera capture and encoding.
