Isaac Sim Version
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: NVIDIA GeForce RTX 3070
- Driver Version: 535.183.01
Topic Description
Detailed Description
I’m working on a custom extension for Isaac Sim, guided by this tutorial, and I’d like to automate the process of enabling and running the extension when launching Isaac Sim with Python. Currently, the extension functions correctly within Isaac Sim, but requires manual activation and pressing “Play.” I’d like to integrate this process programmatically by adapting the Stand Alone example from this tutorial. Can you advise on how to achieve this?
Steps to Reproduce
- Follow the steps in this tutorial to create an extension, and then copy it into a specific directory, such as
~/Documents/Kit/shared/exts/. - Develop a stand-alone application using the guidelines provided in this tutorial.
- Add the following code snippets to include the extension in the application:
from omni.isaac.core.utils.extensions import enable_extension
enable_extension("my_extension") # Extension name
Screenshots
The extension appears in the menu but isn’t opened.
Additional Information
What I’ve Tried
Setting visible=True in extension.py
self._window = ScrollingWindow(title=EXTENSION_TITLE, width=600, height=500, visible=True, dockPreference=ui.DockPreference.LEFT_BOTTOM)
It only shows a blank window, but not initialized.
Additional Context
It would be nice if I could specify the extension path somewhere in the code, so I don’t have to copy or link the extension folder to a pre-defind extension path, such as ~/Documents/Kit/shared/exts/
