when I’m exporting a file in Photoshop with the Nvidia Texture Tool, I get this info message on every export, which makes running actions to automatically export my files impossible (because I have to hit “OK” every time).
Is there a way to disable this message?
Hi tschulu,
Following up on this bug report – I believe we have a fix for this implemented in today’s Texture Tools Exporter 2023.1.0 release!
What was happening was that the Texture Tools Exporter has a field that determines whether it displays messages like this by showing a message box or by printing to a console window. Normally, when actions are running, this field should have made messages silent - but it turned out this field was not set in the Photoshop plugin code!
If you get the chance to test it, please let me know if this issue is fixed for you.
–Neil
