I have an application in which I run deepstream-app with YOLOv4 as the object detector on several small video files (around 0.5 s/ 30fps). I have noticed that each time there is around 3 s start-up delay associated with deepstream. I was wondering if there is any way I can circumvent this problem?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Sure, here are the relevant details: Hardware Platform (Jetson / GPU) GPU T4 • DeepStream Version Deepstream sdk 5.0 • NVIDIA GPU Driver Version (valid for GPU only) 11.3
I am trying to do this for deepstream-app with YOLOv4 object detector.
