How to change the image dimension of realsense images in Isaac ROS!
These are the various image dimensions I can obtain from the Intel RealSense camera, each corresponding to a different frame rate. I want to adjust the input data frequency accordingly. Could you either suggest a method to modify the input frequency or recommend which image dimensions I should use from the camera to achieve the desired frequency?
These are the topics list I’m receiving related to camera inputs
/realsense2_camera/aligned_depth_to_color/camera_info
/realsense2_camera/aligned_depth_to_color/image_raw
/realsense2_camera/aligned_depth_to_color/image_raw/compressed
/realsense2_camera/aligned_depth_to_color/image_raw/compressedDepth
/realsense2_camera/aligned_depth_to_color/image_raw/nitros
/realsense2_camera/aligned_depth_to_color/image_raw/theora
/realsense2_camera/color/image_raw/compressed
/realsense2_camera/color/image_raw/compressedDepth
/realsense2_camera/color/image_raw/theora
/realsense2_camera/color/metadata
/realsense2_camera/depth/camera_info
/realsense2_camera/depth/image_rect_raw
/realsense2_camera/depth/image_rect_raw/compressed
/realsense2_camera/depth/image_rect_raw/compressedDepth
/realsense2_camera/depth/image_rect_raw/theora
/realsense2_camera/depth/metadata
/realsense2_camera/extrinsics/depth_to_color
Intel Realsense Camera - D435
Hardware - Nvidia Orin Agix
Hi @sarthakgarg0303
To change the camera sensor, you need to modify the specific roslaunch.py file for the desired demo.
For example, if you are working with Isaac ROS vslam, the file: isaac_ros_visual_slam_realsense.launch.py there is an option to change the camera setup
If you are working with Isaac ROS pose estimation the camera resolution is set to these lines:
But remember that the pose estimation demo is trained at 640x480. If you want to work at other resolutions, you need to update also the model.
Best,
Raffaello
Thank you @Raffaello , I’m working with foundationpose pose estimation using Isaac ROS, I changed the yaml file to get the desired inputs from realsense camera. The depth and camera_info are obtained at 60hz but still the rgb inputs are not produced at 60 hz as explicitly mentioned, they are obtained at somewhere around 40hz.
And when I run this command to get the inputs from camera, I’m getting all the three inputs of depth, rgb, camera info all at 60 hz.
ros2 launch realsense2_camera rs_launch.py depth_module.depth_profile:=640x480x60 rgb_camera.color_profile:=640x480x60
This is the jetson consumption!
Hi @sarthakgarg0303
Can you please share the launch file needed to run this demo? Also, please double-check if you have modified the correct yaml file.
I noticed that your Jetson is running other software that may be consuming CPU and GPU. Please disable any other running applications.
Best,
Raffaello
Hi @Raffaello I’m using this command to launch the foundationpose, no changes in isaac_ros_examples.launch.py
ros2 launch isaac_ros_examples isaac_ros_examples.launch.py launch_fragments:=realsense_mono_rect_depth,foundationpose_tracking mesh_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/isaac_ros_foundationpose/Mac_and_cheese_0_1/Mac_and_cheese_0_1.obj texture_path:=${ISAAC_ROS_WS}/isaac_ros_assets/isaac_ros_foundationpose/Mac_and_cheese_0_1/materials/textures/baked_mesh_tex0.png score_engine_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/models/foundationpose/score_trt_engine.plan refine_engine_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/models/foundationpose/refine_trt_engine.plan rt_detr_engine_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/models/synthetica_detr/sdetr_grasp.plan
And the corrected yaml file isaac_ros_realsense/config/realsense_mono_depth.yaml is
enable_infra1: false
enable_infra2: false
align_depth.enable: true
depth_module.depth_profile: "640x480x60"
rgb_camera.color_profile: "640x480x60"
depth_module.enable_auto_exposure: false
rgb_camera.enable_auto_exposure: false
# depth_module.exposure: 15000
# rgb_camera.exposure: 15000
rgb_camera.auto_exposure_priority: false
rgb_camera.auto_exposure_roi.top: 160
rgb_camera.auto_exposure_roi.bottom: 320
rgb_camera.auto_exposure_roi.left: 160
rgb_camera.auto_exposure_roi.right: 480
