How to check DDR bandwidth utilization of each core?
DRIVE OS Version: 7.0.3.0-0010
HW Board Variate: p3960-10-sw03
Issue Description: how to check DDR bandwidth utilization of each core.
for example, CPU/GPU/ISP/ENC/VIC, each consuming ?GBps.
through tegrastats, only saw loading of each core
Dear @snow.yin ,
Tegrastars does not give memory statistics.
Does User Guide — Nsight Systems helps ?
could you please give more specific guide on this topic, like which cmd would collect the info we need?
Nsight may support GPU BW, but I did not see anything related to other cores.
I was expected something more clear and simple like below:
Dear @snow.yin ,
Using nsys, you can collected soc metrics. Please see User Guide — Nsight Systems.
The SoC metrics are listed at User Guide — Nsight Systems.
Also, please take a look at emc_log tool(EMC Log Utility — NVIDIA DriveOS 7.2.5 Linux SDK Early Access Developer Guide). It has list of clients and using stats parameter you can get bandwidth. Give a try and let us know your feedback.
Hi @SivaRamaKrishnaNV
Thank you so much, we’ll check this on 7.2.5 later
