We changed DEVKit display port from HDMI to DP. The DP2_AUX_CH pin default setting is I2C7_CLK for HDMI. We should change this pin to DP_AUX_CH2_P for DP.
But after I changed the pin to DP_AUX_CH2_P in pinmux, the generated file tegra19x-jetson_agx_xavier-pinmux.dtsi did not change.
How to change the pin from I2C7 to DP_AUX_CH2_P ?
Sorry for the late response, is this still an issue to support? Thanks
