I use PX2 AutoCruise with DriveWorks SDK version 1.2.400 with 8 cams of type ar0231-rccb-bae-sf3324 connected.
I also have testet the setup with sample_camera_multiple_gmsl --selector-mask=0000111100
to verify that the B cams are running.
Now I want to use recorder to save the h264 data on my ext4 formatted usb drive.
I call recorder with the following rig file for 2 cameras out of the 8:
"rig": {
"sensors": [
"name": "camera_capture_a",
"nominalSensor2Rig": {
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"parameter": "camera-type=ar0231-rccb-bae-sf3324,csi-port=a,camera-count=2,camera-mask=0011,format=h264,fifo-size=30,file-buffer-size=4194304",
"properties": {
"Model": "ftheta",
"bw-poly": "0.0 0.00102669443003833 3.77865596590254e-08 -2.1812513600894e-11 4.76916107246175e-14",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"protocol": "camera.gmsl",
"sensor2Rig": {
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"vehicle": {
"valid": true,
"value": {
"COMMENT": "steeringCoefficient is not validated",
"axlebaseFront": 1.582,
"axlebaseRear": 1.575,
"bumperFront": 0.912,
"bumperRear": 1.109,
"centerOfMassToRearAxle": 1.564,
"frontCorneringStiffness": 30654.0,
"height": 1.473,
"inertia": 1780.8,
"length": 4.872,
"mass": 1779.4,
"rearCorneringStiffness": 36407.0,
"steeringCoefficient": 14.8,
"wheelDiameter": 0.673,
"wheelbase": 2.85,
"width": 1.852,
"widthWithMirrors": 2.121
"version": 2
This leads to the following output and question:
[15-7-2020 0:39:28] Initialize DriveWorks SDK v1.2.400
[15-7-2020 0:39:28] Release build with GNU 4.9.4 from v1.2.0-rc11-0-ga7f5475 against Vibrante PDK v5.0.10.3
[15-7-2020 0:39:28] Platform: Detected Drive PX2 - Tegra A
[15-7-2020 0:39:28] TimeSource: monotonic epoch time offset is 1594736413029575
[15-7-2020 0:39:28] TimeSource: PTP ioctl returned error. Synchronized time will not be available.
[15-7-2020 0:39:28] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[15-7-2020 0:39:28] Platform: number of GPU devices detected 1
[15-7-2020 0:39:28] Platform: currently selected GPU device integrated ID 0
[15-7-2020 0:39:28] SDK: Resources mounted from /usr/local/driveworks-1.2/data/resources
[15-7-2020 0:39:28] SDK: Create NvMediaDevice
[15-7-2020 0:39:28] SDK: Create NvMediaIPPManager
[15-7-2020 0:39:28] egl::Display: found 1 EGL devices
[15-7-2020 0:39:28] egl::Display: use drm device: drm-nvdc
[15-7-2020 0:39:28] SensorFactory::createSensor() → camera.gmsl, camera-type=ar0231-rccb-bae-sf3324,csi-port=a,camera-count=2,camera-mask=0011,format=h264,fifo-size=10,file-buffer-size=4194304
[15-7-2020 0:39:28] CameraGMSL: required FPS = 30, resolution = 1920x1208
***** aurix state *****
CAM_PWR_ON: 0x1
TEGRA_GMSL: TEGRA B
TEGRA_FPDL: TEGRA B
TEGRA_A_HDMI: MXM
TEGRA_B_HDMI: MXM
TEGRA_PCI: TEGRA B
FAN_STATE: UNKNOWN
nvmedia isc: TacpCamPowerControl: 241: Camera(s) are already powered on. Power cycling the camera(s)
CAM_PWR_ON: 0x0
TEGRA_GMSL: UNKNOWN
TEGRA_FPDL: UNKNOWN
TEGRA_A_HDMI: UNKNOWN
TEGRA_B_HDMI: UNKNOWN
TEGRA_PCI: UNKNOWN
FAN_STATE: UNKNOWN
CAM_PWR_ON: 0x1
TEGRA_GMSL: UNKNOWN
TEGRA_FPDL: UNKNOWN
TEGRA_PCI: UNKNOWN
FAN_STATE: UNKNOWN
[15-7-2020 0:39:29] CameraGMSL: default IPP event callback function set
[15-7-2020 0:39:29] CameraGMSL: serializer bitrate not specified. Using 8000000.
Rig: 1.json NewSink: /dev/null
[15-7-2020 0:39:29] SensorManager: started
Press s to start, just to see progress, q to quit.
[15-7-2020 0:39:30] CameraGMSL: Frame: 23 CaptureTimestamp: 29957120423 - ICP DROP in camera 1
[15-7-2020 0:39:30] CameraGMSL: Frame: 24 CaptureTimestamp: 29957153781 - ICP DROP in camera 1
[15-7-2020 0:39:30] CameraGMSL: Frame: 25 CaptureTimestamp: 29957187101 - ICP DROP in camera 1
[15-7-2020 0:39:30] CameraGMSL: Frame: 26 CaptureTimestamp: 29957220434 - ICP DROP in camera 1
Where do the drop frames come from?
What do I have to change in the rig file in order to record all 8 cameras?
btw: When I use this rig file with recorder-qtgui I get the failure status with an error message in the terminal saying:
/usr/local/driveworks/tools/capture/recorder-qtgui 1.json
QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
recorder-qtgui: recorderSendCmd: failure!
Error: timeout, unable to stop recoder2 gracefully!
Could someone please give me a hint, what’s the issue? Cheers.
