After flashing our PX2 to DW 1.2.400, the input format for recorder has changed.
The new format can be found at /usr/local/driveworks/tools/capture/configs/hyperion7_1/release.json
and defines 2 cameras, one per channel, second one in slave mode.
"rig": {
"sensors": [
"name": "camera:front:center:120fov",
"nominalSensor2Rig": {
"quaternion": [...],
"t": [...]
"parameter": "camera-type=ar0231-rccb-bae-sf3324
,csi-port=a,camera-count=1,format=h264
,output-format=yuv,fifo-size=12,file-buffer-size=4194304",
"properties": {
"Model": "ftheta",
"bw-poly": "0.0 0.00102669443003833 3.77865596590254e-08 -2.1812513600894e-11 4.76916107246175e-14",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"protocol": "camera.gmsl",
"sensor2Rig": {
"t": [...]
"name": "camera:front:center:60fov",
"t": [...]
"parameter": "camera-type=ar0231-rccb-bae-sf3325,csi-port=c
,camera-count=1,format=h264,output-format=yuv
,fifo-size=12,slave=1,file-buffer-size=4194304",
"properties": {
"Model": "ftheta",
"bw-poly": "0.0 0.000545421498827636 -1.6216719633103e-10 -4.64720492990289e-12 2.85224527762934e-16",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"sensor2Rig": {
"t": [...]
Since before PX2 update I was able to record 8 cams ( 4 on port ab, 4 on port cd )
I wonder, how the rig configuration has to be changed in order to record the 8 cameras again?
Thanks for your support
