We were able to record 2 cameras to a 10 GbE server using the recorder you mentioned above, however we’re having issues with more than 2 cameras. Even with cameras split across multiple CSI ports we start seeing ICP drops across all camera. I believe this is likely a configuration error on our end but I am stuck as to what we need to change to get these errors to disappear. Here is a screenshot of the error we get when we start the recorder with a 3 or 4 camera configuration. With 2 cameras we see no frame drops at all. I have also attached our rig configuration we’re using to attempt to record. Thanks!
"rig": {
"sensors": [
"name": "camera:front:center:120fov",
"nominalSensor2Rig": {
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"parameter": "camera-type=ar0231-rccb-ae-ss3322,csi-port=c,camera-count=2,siblingIndex=0,format=raw,output-format=raw,slave=0,file-buffer-size=8192",
"properties": {
"Model": "ftheta",
"bw-poly": "0.0 0.000545421498827636 -1.6216719633103e-10 -4.64720492990289e-12 2.85224527762934e-16",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"protocol": "camera.gmsl",
"sensor2Rig": {
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"name": "camera:back:center:120fov",
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"parameter": "camera-type=ar0231-rccb-ae-ss3322,csi-port=c,camera-count=2,siblingIndex=1,format=raw,output-format=raw,slave=0,file-buffer-size=8192",
"properties": {
"Model": "ftheta",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"sensor2Rig": {
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"name": "camera:back:right:120fov",
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"parameter": "camera-type=ar0231-rccb-ae-ss3322,csi-port=e,camera-count=2,siblingIndex=0,format=raw,output-format=raw,slave=0,file-buffer-size=8192",
"properties": {
"Model": "ftheta",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"sensor2Rig": {
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"name": "camera:back:left:120fov",
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"parameter": "camera-type=ar0231-rccb-ae-ss3322,csi-port=e,camera-count=2,siblingIndex=1,format=raw,output-format=raw,slave=0,file-buffer-size=8192",
"properties": {
"Model": "ftheta",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"sensor2Rig": {
"quaternion": [
0.5,
-0.5,
0.5,
-0.5
"t": [
1.77,
0.0,
1.47
"name": "can:vehicle",
"quaternion": [
0.0,
0.0,
0.0,
1.0
"t": [
0.0,
0.0,
0.0
"parameter": "device=can0,file-buffer-size=8192",
"properties": null,
"protocol": "can.socket",
"sensor2Rig": {
"quaternion": [
0.0,
0.0,
0.0,
1.0
"t": [
0.0,
0.0,
0.0
"vehicle": {
"valid": true,
"value": {
"COMMENT": "steeringCoefficient is not validated",
"axlebaseFront": 1.582,
"axlebaseRear": 1.575,
"bumperFront": 0.912,
"bumperRear": 1.109,
"centerOfMassToRearAxle": 1.564,
"frontCorneringStiffness": 30654.0,
"height": 1.473,
"inertia": 1780.8,
"length": 4.872,
"mass": 1779.4,
"rearCorneringStiffness": 36407.0,
"steeringCoefficient": 14.8,
"wheelDiameter": 0.673,
"wheelbase": 2.85,
"width": 1.852,
"widthWithMirrors": 2.121
"version": 2
