I have obtained a trial license for NVIDIA AI Enterprise, configured the cloud license server, and downloaded the token.
I have installed the nvidia-vgpu-ubuntu-aie-580_580.82.02_amd64.deb driver on the Linux host.
Then, I am following the client licensing guide to configure the license on the host machine. I have noticed that there is no /etc/nvidia folder. However, I have created it, created /etc/nvidia/gridd.conf and copied the token to /etc/nvidia/ClientConfigToken folder with proper permissions. I do not have nvidia-gridd service, so I restarted the nvidia-vgpu-mgr.service service.
License information is not populated. How to configure the license for vGPU on the host machine?
user@hcg-srv-cn002:~/virtual-gpu-manager-7_v7.1$ nvidia-smi -q -i 0
==============NVSMI LOG==============
Timestamp : Sat Oct 18 01:13:47 2025
Driver Version : 580.82.02
CUDA Version : Not Found
vGPU Driver Capability
Heterogenous Multi-vGPU : Supported
Attached GPUs : 8
GPU 00000000:19:00.0
Product Name : NVIDIA H200
Product Brand : NVIDIA
Product Architecture : Hopper
Display Mode : Requested functionality has been deprecated
Display Attached : Yes
Display Active : Disabled
Persistence Mode : Enabled
Addressing Mode : N/A
vGPU Device Capability
Fractional Multi-vGPU : Supported
Heterogeneous Time-Slice Profiles : Supported
Heterogeneous Time-Slice Sizes : Supported
Homogeneous Placements : Supported
MIG Time-Slicing : Not Supported
MIG Time-Slicing Mode : Disabled
MIG Mode
Current : Disabled
Pending : Disabled
Accounting Mode : Enabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : 1754324048185
GPU UUID : GPU-e96646ea-b71e-b205-3792-441478561263
GPU PDI : 0x418fb9ff076c951c
Minor Number : 0
VBIOS Version : 96.00.A5.00.03
MultiGPU Board : No
Board ID : 0x1900
Board Part Number : 695-2G520-0280-001
GPU Part Number : 2335-895-A1
FRU Part Number : N/A
Platform Info
Chassis Serial Number : N/A
Slot Number : N/A
Tray Index : N/A
Host ID : N/A
Peer Type : N/A
Module Id : 2
GPU Fabric GUID : N/A
Inforom Version
Image Version : G520.0280.02.02
OEM Object : 2.1
ECC Object : 7.16
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : Disabled
GPU Virtualization Mode
Virtualization Mode : Host VGPU
Host VGPU Mode : SR-IOV
vGPU Heterogeneous Mode : Disabled
GPU Recovery Action : None
GSP Firmware Version : 580.82.02
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x19
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x2
Device Id : 0x233510DE
Bus Id : 00000000:19:00.0
Sub System Id : 0x18BE10DE
GPU Link Info
PCIe Generation
Max : 5
Current : 5
Device Current : 5
Device Max : 5
Host Max : N/A
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 639 KB/s
Rx Throughput : 659 KB/s
Atomic Caps Outbound : FETCHADD_32 FETCHADD_64 SWAP_32 SWAP_64 CAS_32 CAS_64
Atomic Caps Inbound : N/A
Fan Speed : N/A
Performance State : P0
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Clocks Event Reasons Counters
SW Power Capping : 0 us
Sync Boost : 0 us
SW Thermal Slowdown : 0 us
HW Thermal Slowdown : 0 us
HW Power Braking : 0 us
Sparse Operation Mode : Disabled
FB Memory Usage
Total : 143771 MiB
Reserved : 1174 MiB
Used : 0 MiB
Free : 142598 MiB
BAR1 Memory Usage
Total : 262144 MiB
Used : 1 MiB
Free : 262143 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
GPU : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
DRAM Encryption Mode
Current : N/A
Pending : N/A
ECC Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
SRAM Correctable : 0
SRAM Uncorrectable Parity : 0
SRAM Uncorrectable SEC-DED : 0
DRAM Correctable : 0
DRAM Uncorrectable : 0
Aggregate
SRAM Threshold Exceeded : No
Aggregate Uncorrectable SRAM Sources
SRAM L2 : 0
SRAM SM : 0
SRAM Microcontroller : 0
SRAM PCIE : 0
SRAM Other : 0
Channel Repair Pending : No
TPC Repair Pending : No
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 3072 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 27 C
GPU T.Limit Temp : 60 C
GPU Shutdown T.Limit Temp : -8 C
GPU Slowdown T.Limit Temp : -2 C
GPU Max Operating T.Limit Temp : 0 C
GPU Target Temperature : N/A
Memory Current Temp : 28 C
Memory Max Operating T.Limit Temp : 0 C
GPU Power Readings
Average Power Draw : 81.96 W
Instantaneous Power Draw : 82.21 W
Current Power Limit : 700.00 W
Requested Power Limit : 700.00 W
Default Power Limit : 700.00 W
Min Power Limit : 200.00 W
Max Power Limit : 700.00 W
GPU Memory Power Readings
Average Power Draw : 41.11 W
Instantaneous Power Draw : N/A
Module Power Readings
Average Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Power Smoothing : N/A
Workload Power Profiles
Requested Profiles : N/A
Enforced Profiles : N/A
Clocks
Graphics : 345 MHz
SM : 345 MHz
Memory : 3199 MHz
Video : 765 MHz
Applications Clocks
Graphics : 1980 MHz
Memory : 3201 MHz
Default Applications Clocks
Graphics : 1980 MHz
Memory : 3201 MHz
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 1980 MHz
SM : 1980 MHz
Memory : 3201 MHz
Video : 1545 MHz
Max Customer Boost Clocks
Graphics : 1980 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Fabric
State : Completed
Status : Not Supported
CliqueId : 0
ClusterUUID : 00000000-0000-0000-0000-000000000000
Health
Summary : N/A
Bandwidth : N/A
Route Recovery in progress : N/A
Route Unhealthy : N/A
Access Timeout Recovery : N/A
Incorrect Configuration : N/A
Processes : None
Capabilities
EGM : disabled
