How to connect my LiDAR(UART) with TX2
Hello all,
My LiDAR use UART to communicate, but I’m not pretty sure about how to connect the pin with TX2. Currently I use USB HUB to connect my 3 LiDARs, but when I run my program for few seconds, TX2 will stuck and reboot.
I tried to use J21 pin 8 and 10, where I saw UART on the TX2 developer kit, but when I connect it with my LiDAR, TX2 will stuck ant the NVIDIA logo screen and not boot. And I don’t know how to use other UART port like J17 seems like support UART.
Sorry for being a layman and thanks for your help!
Hi asyuan0506,
Please share the full serial console log at this moment.
You can also share the full dmesg and device tree for further check.
Thanks for your response, But I’m not sure what I provided is correct or not.
Jetpack version : 4.4.1 (Since I saw my L4T version is : 32.4.4-20201016123640
Serial console log, dmesg, device tree are in the txt file.
Thanks for your help!!
Device tree.txt (4.7 KB)
dmesg_log.txt (62.7 KB)
Serial console log.txt (21.6 KB)
From the serial console log, it seems booting successful w/o any hang issue.
It is not the device tree I requested.
Please run the following command on your board and share extracted_proc.dts as file here.
$ sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
[    0.971665] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
Are you using /dev/ttyS0 for your UART device(LiDAR)?
It seems it is used for debug UART currently.
Seems like I can’t upload .dts file here, so here is the link of extracted_proc.dts file : https://drive.google.com/file/d/1JNkuAcbdVtnqOuolzBdeTDmigZlck9Jk/view?usp=sharing
No, I used /dev/ttyS0 to connect with my computer, because that is the only way I know to provide my serial console log. But when I first asked the question (Jul 27), I connect those pin (pin 8, 10) for my LiDAR. I guess it’s because those pins are used for debug by default? But I don’t know how to manage it, and I don’t know are there other pins are used for UART?
Thanks for your help!!!
The file here is I ran your command, and what it showed on terminal.
terminal text.txt (78.0 KB)
For debug serial console, please use UART interface from Serial Port header (J17).
=> c280000.serial (uartc)
For connecting with your LiDAR module, please user UART interface from PIN8/PIN10 of 40-pins header.
=> 3100000.serial(uarta)
You can run the following commands to prevent debug messages output from ttyS0.
$ sudo systemctl stop nvgetty
$ sudo systemctl disable nvgetty
$ sudo systemctl stop serial-getty@ttyS0.service
$ sudo systemctl disable serial-getty@ttyS0.service
Thanks for your reply,
I tried ran these four commands at terminal, and shut down Jetson TX2, and after it, I plugged in my LiDAR using PIN8 and 10 and tried to boot it, it will still hang at Nvidia logo screen, and still couldn’t enter the Ubuntu login screen.
Furthermore, I want to ask if there are other UART pins for my LiDARs, because I have three, I wondered if there are other pins for it, thanks.
Thanks for your help.
Please use debug UART from J17 for serial console log.
You should be able to use the UART from 40pins-header for your custom use case like LiDAR.
I would suggest you shorting PIN8/PIN10 to verify UART loopback test before connecting it with your module.
Yes, you can also try them.
You have 3110000.serial which should be from M.2 key E port.
[    0.973009] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
Thanks for your fast reply,
How to use debug UART from J17 for serial console log? Do I need to connect something? Because I don’t know have the pin diagram of J17.
Please refer to this Table 19 and connect UART1_RX, UART1_TX and GND with the serial console cable connecting with your host.
