I want to create a ghost articulation similar to the Franka Demo to visualize the target position of the robot or its trajectory, so I need to disable the rigid body property while also can using the ArticulationView to set joint and root position, I’d like to know how to do it, thanks!
Related topics
| Articulation - set instant joint position w/o physics or collision | 2 | 225 | November 4, 2024 | |
| Create ArticulationView using Articulation | 2 | 235 | November 5, 2024 | |
| Failed to query Articulation in python script | 10 | 188 | October 28, 2025 | |
| Creating Articulation that are pure kinematics | 3 | 148 | September 8, 2025 | |
| Isaac Sim python scripting no articulation view | 9 | 1950 | August 22, 2024 | |
| Rigid body lock pose and lock rotation doesn't work when I set articulation root | 1 | 168 | November 27, 2024 | |
| ArticulationController questions | 4 | 1786 | October 25, 2023 | |
| Replacing ArticulationView to enable Force Field | 1 | 321 | April 15, 2024 | |
| Cannot add articulation to my robot | 5 | 545 | March 13, 2023 | |
| Problem applying action (through target joint position) to ArticulaitonView | 1 | 249 | June 19, 2024 |
