Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
[yes] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
Target Operating System
[yes] Linux
QNX
other
Hardware Platform
[yes] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
[yes] 1.6.0.8170
other
Host Machine Version
[yes] native Ubuntu 18.04
other
Dear @wang_chen2,
Is this eglStream and opengl duplicate?
Are you asking for DW APIs?
Hi, @SivaRamaKrishnaNV,
yes, they are similar.
Recently, I am learning NvMedia not DW. Can draw boxes on images via DW or NvMedia?
Dear @wang_chen2,
Could you check DriveWorks SDK Reference: Visualization Interface.
You may check DW DNN samples to know how to use APIs to draw bounding boxes on display video.
Dear SivaRamaKrishnaNV,
I still do not know how to draw boxes on image. And I do not how to choose NvMedia or DW?
I do not clear what interface I needed! The doc about NvMedia and DW samples are both not detailed.
Maybe I had not explain my questions very good. My questions are following:
1、how to read image from image file or video file?
2、how to display images and render them with boxes?
Dear @wang_chen2 ,
NvMedia has APIs to access camera sensor data, perform encoding/decoding, perform image processing operation using VIC engine etc. It is a low level API. DW is like high level library built on top on NvMedia/CUDA which provides several functionalities like reading sensor data, integrate models, perform imaging operations using accelerators on the Xavier SoC. Please check the documentation for more details.
Using DW, you can create a SimpleCamera class object with right parameters to read video file and get frames. Please check getNextFrame() and onProcess() functions in sample_object_detector_tracker DW sample.
Could you check onRender() function in the same sample to know how to use dwRenderEngine APIs to draw boxes
Ok, Thanks for your replay.
