My ethernet device is ConnectX-3(MT27500 Family), which has 10GBASE-KR F/W.
The device is connected to another 10GBASE-KR device(Not ethernet switch), which is the auto-negotiation is ‘on’. The connection is not linked because my device is the auto-negotiation is ‘off’.
I would like to know how I can enable the auto-negotiation.
That said, there are a few considerations to check:
If the ConnectX-3 is set to auto-negotiate in a back-to-back connection with another HCA, one of the devices in the link will need to be set to a forced speed in order for the link to be established. Where the above command would enable autonegiation, a back-to-back peer would need:
ethtool -s enp4s0 speed 10000 duplex full
Check the ConnectX-3 firmware release notes’ for the version you are using and verify that the cable/transceiver connecting the ConnectX-3 and peer device as well as the peer device itself are listed in the compatibility matrices. For more information, select your model of ConnectX-3 from the link below, select the firmware version you are using, and the page will provide a link to the Firmware Release notes:
If the cable and peer device are validated within the firmware’s Release Notes and you are still unable to establish a link, please open a case with our support team as we will require more information in order to assist with the issue. If you do not have a valid support contract, please contact Networking-contracts@nvidia.com to discuss a contract.
