Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
[*] DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
[*] native Ubuntu 18.04
other
I want to use perf tool on AGX. But found following issue.
$ perf top
WARNING: perf not found for kernel 4.14.150-rt67
You may need to install the following packages for this specific kernel:
linux-tools-4.14.150-rt67-tegra
linux-cloud-tools-4.14.150-rt67-tegra
You may also want to install one of the following packages to keep up to date:
linux-tools-tegra
linux-cloud-tools-tegra
$ sudo apt-get install linux-tools-tegra
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package linux-tools-tegra
$ gunzip -c /proc/config.gz | grep PERF
CONFIG_CGROUP_PERF=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
# CONFIG_PCIEASPM_PERFORMANCE is not set
CONFIG_HW_PERF_EVENTS=y
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
# CONFIG_CLS_U32_PERF is not set
# CONFIG_BCMDHD_CUSTOM_NET_PERF_TEGRA is not set
CONFIG_DEVFREQ_GOV_PERFORMANCE=y
CONFIG_NTB_PERF=m
CONFIG_HARDLOCKUP_DETECTOR_PERF=y
# CONFIG_RCU_PERF_TEST is not set
CONFIG_SECURITY_PERF_EVENTS_RESTRICT=y
/usr/src$ ls
tensorrt
Ref this topic, I need to download kernel headers file firstly. Where I can get 4.14.150-rt67 header file?
I have another try below, but still doesn’t work for me.
- scp
~/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-oss-src/kernelfrom PC to AGX target side. - Do install perf again with make command. Still doesn’t work for me.
~/kernel/tools/perf$ sudo make
BUILD: Doing 'make -j7' parallel build
Warning: Kernel ABI header at 'tools/include/uapi/drm/i915_drm.h' differs from latest version at 'include/uapi/drm/i915_drm.h'
Warning: Kernel ABI header at 'tools/include/uapi/linux/kvm.h' differs from latest version at 'include/uapi/linux/kvm.h'
Warning: Kernel ABI header at 'tools/arch/x86/include/asm/cpufeatures.h' differs from latest version at 'arch/x86/include/asm/cpufeatures.h'
Warning: Kernel ABI header at 'tools/arch/x86/include/uapi/asm/kvm.h' differs from latest version at 'arch/x86/include/uapi/asm/kvm.h'
Auto-detecting system features:
... dwarf: [ OFF ]
... dwarf_getlocations: [ OFF ]
... glibc: [ on ]
... gtk2: [ OFF ]
... libaudit: [ OFF ]
... libbfd: [ OFF ]
... libelf: [ OFF ]
... libnuma: [ OFF ]
... numa_num_possible_cpus: [ OFF ]
... libperl: [ on ]
... libpython: [ OFF ]
... libslang: [ OFF ]
... libcrypto: [ OFF ]
... libunwind: [ OFF ]
... libdw-dwarf-unwind: [ OFF ]
... zlib: [ on ]
... lzma: [ on ]
... get_cpuid: [ OFF ]
... bpf: [ on ]
Makefile.config:291: No libelf found. Disables 'probe' tool, jvmti and BPF support in 'perf record'. Please install libelf-dev, libelf-devel or elfutils-libelf-devel
Makefile.config:399: No sys/sdt.h found, no SDT events are defined, please install systemtap-sdt-devel or systemtap-sdt-dev
Makefile.config:472: Disabling post unwind, no support found.
Makefile.config:522: No libaudit.h found, disables 'trace' tool, please install audit-libs-devel or libaudit-dev
Makefile.config:533: No libcrypto.h found, disables jitted code injection, please install libssl-devel or libssl-dev
Makefile.config:548: slang not found, disables TUI support. Please install slang-devel, libslang-dev or libslang2-dev
Makefile.config:562: GTK2 not found, disables GTK2 support. Please install gtk2-devel or libgtk2.0-dev
Makefile.config:619: No 'python-config' tool was found: disables Python support - please install python-devel/python-dev
Makefile.config:725: No numa.h found, disables 'perf bench numa mem' benchmark, please install numactl-devel/libnuma-devel/libnuma-dev
GEN perf-archive
GEN perf-with-kcore
CC util/header.o
LD util/libperf-in.o
LD libperf-in.o
AR libperf.a
LINK perf
