hi all~
in a previous post:
https://devtalk.nvidia.com/default/topic/898775/jetson-tk1/how-to-use-pcie-x4-of-tk1-/
Jachen ever mentioned that
in /boot/extlinux/extlinux.conf
if we set the value of ‘lane_owner_info’ to 1 (originally it was 6)
then, the PCIE lane ownership would be configured as PCIe x4_x1 after a reboot.
In my customized board:
PCIE Controller-1 is connected as follows:
PEX_CLK1P/N ---------> FPGA.PCIE-CORE.CLKP/N
PEX_L0_RST_N ---------> FPGA.PCIE-CORE.RST_N
PEX_L0_CLK_REQ_N <--------- tied logic low (1'b0)
PEX_TX4P/N ---------> FPGA.PCIE_RXP/N [0]
PEX_TX3P/N ---------> FPGA.PCIE_RXP/N [1]
PEX_TX2P/N ---------> FPGA.PCIE_RXP/N [2]
PEX_USB3_TX1P/N ---------> FPGA.PCIE_RXP/N [3]
PEX_RX4P/N <--------- FPGA.PCIE_TXP/N [0]
PEX_RX3P/N <--------- FPGA.PCIE_TXP/N [1]
PEX_RX2P/N <--------- FPGA.PCIE_TXP/N [2]
PEX_USB3_RX1P/N <--------- FPGA.PCIE_TXP/N [3]
PCIE Controller-2 is connected as follows:
PEX_CLK2P/N ---------> RTL8111GS(ETH-PHY).CLKP/N
PEX_L1_RST_N ---------> RTL8111GS(ETH-PHY).RST_N
PEX_L1_CLK_REQ_N <--------- RTL8111GS(ETH-PHY).CLK_REQ_N
USB3_TX0P/N ---------> RTL8111GS(ETH-PHY).HSIP/N
USB3_RX0P/N <--------- RTL8111GS(ETH-PHY).HSOP/N
NOTE:
the above connection is made according to the USECASE-3 of
Table 40. USB 3.0, PCIe & SATA Lane Mapping Use Cases, pp114 of the
"TegraK1_Embedded_Design_Guide"
USECASE-3 = pcie_x4_x1 + sata
will the above PCIE lane mapping work (at least “lspci -vvv” is supposed to
dump some PCIE info about ETH-PHY and FPGA )
by just changing the ‘lane_owner_info’ in /boot/extlinux/extlinux.conf
from 6 to 1 ?
is it all that needs (given the correct hardware connection as shown above in my customized design) ?
