Hi All:
I want to test TX2 devkit RNDIS function, but it failed. My test procedure just as follows:
- TX2 devkit connect a WIFI AP.
- turn off ubuntu PC’s WIFI and plug out ethernet.
- connect TX2 devkit and a ubuntu PC and test PC network function.
I use “lsusb -t” can see RNDIS interface as follows, but it seems this function is fail.
adam@adam-Latitude:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
|__ Port 1: Dev 7, If 5, Class=Communications, Driver=cdc_ether, 480M
|__ Port 1: Dev 7, If 3, Class=CDC Data, Driver=cdc_acm, 480M
|__ Port 1: Dev 7, If 1, Class=CDC Data, Driver=rndis_host, 480M
|__ Port 1: Dev 7, If 6, Class=CDC Data, Driver=cdc_ether, 480M
|__ Port 1: Dev 7, If 4, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 1: Dev 7, If 2, Class=Communications, Driver=cdc_acm, 480M
|__ Port 1: Dev 7, If 0, Class=Communications, Driver=rndis_host, 480M
|__ Port 5: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 5: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 7: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 7: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
Do you know how to enable USB RNDIS?
