As far as I know, the Jetson Xavier NX has one M.2 Key M interface that supports PCIe x4, and one M.2 Key E interface that supports PCIe x1. However, I have three devices that require PCIe x1 interfaces to connect to the Jetson Xavier NX. What should I do?
Related topics
| Jetson Xavier NX Dev Kit M.2 to PCIe (Root) Connection | 2 | 756 | September 28, 2021 | |
| PCIe Bifurcation on Xavier NX, Nano, and TX2 NX | 4 | 937 | January 27, 2022 | |
| Interfacing between FPGA(Xilinx) / Jetson Xavier | 3 | 2681 | July 6, 2022 | |
| Is it possible to connect SSD to Xavier NX PCIe1(Ctrl #4)? | 5 | 554 | November 24, 2022 | |
| Is it possible to connect two Xavier NXes over PCIe? | 1 | 646 | March 2, 2021 | |
| Can it possible that Jetson Xavier NX be used as host computer using PCIe M.2 Key M port? | 2 | 533 | November 4, 2020 | |
| Jetson Xavier NX Module PCIE0 Port Configuration Options | 3 | 1048 | April 26, 2022 | |
| Jetson Xavier NX - PCIe port | 1 | 769 | February 8, 2023 | |
| Is there a way to connect mini pcie to NX? | 3 | 996 | November 10, 2020 | |
| Xavier NX using PCIE 2+2 mode? | 1 | 1034 | April 14, 2021 |
