" Next, use the content browser to navigate to Isaac/Robots/JetBot and click and drag jetbot.usd onto the stage."
Is the content browser under the viewport? I can not find the jetbot.usd by using the broswer?
https://docs.omniverse.nvidia.com/isaacsim/latest/gui_tutorials/tutorial_gui_omnigraph.html
@2703951170 yes, it would be good to set up a localhost nucleus server. that’s how you can access NVIDIA assets that were shipped with OV. Below shows two ways you can access the Jetbot assuming you have set up localhost:
You can set up localhost via the Nucleus tab of your OV Launcher.
and just in case you need it - follow the steps outlined in this post to setup your localhost if you need a step by step instruction:
Thank you for showing me such detailed solutions!
