How to Fix jtop “JetPack Missing” (Works on Brand-New Jetson / Latest JetPack) [SOLUTION]
If jtop/jetson-stats stops working after updating JetPack/L4T, it’s often because the version you have installed on the Jetson is not updated with the newest L4T → JetPack mappings.
The latest jetson_stats repository already contains the updated mapping file, but the version you installed (apt/pip/old package) may still be behind.
So the fix is simple: grab the newest jetson_variables.py from the official repo, replace your local file, reboot, and jtop works again.
1) Download the latest jetson_variables.py from the official repo
  1. Open your browser on the Jetson.
  2. Go to the official jetson_stats GitHub repository.
  3. Navigate to:
    jtopcorejetson_variables.py
  4. Open the file and download/save the raw file (or copy its full contents).
You now have the latest version of jetson_variables.py from the repo.
2) Open your installed file.
  1. Open the file you showed earlier:
    .../jtop/core/jetson_variables.py
Common location (varies by install method, but this is typical):
  • /usr/local/lib/python3.x/dist-packages/jtop/core/jetson_variables.py
3) Replace the file content with the latest one
  • Open the downloaded latest jetson_variables.py
  • Copy all contents
  • Paste into your installed jetson_variables.py (replace everything)
  • Save
5) Reboot
Reboot the Jetson
jtop reads JetPack/L4T info using a version-mapping table inside jetson_variables.py.
When JetPack updates, older installed builds may not recognize the new version numbers. The latest GitHub file includes the updated mappings, but your installed package might not.
Replacing jetson_variables.py updates those mappings immediately.
I hope this works for you all :)
Best,
Renato
Thanks for your sharing
